Relation "oc_appconfig" does not exist after attempted migration
example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.2
Operating system and version (, Ubuntu 20.04): Unraid 6.11.1
I have followed the migration steps for migrating the files and database to the new AIO set up (AIO beta 4.0.0, both on 25.0.2). [all-in-one/migration.md at main · nextcloud/all-in-one · GitHub]
I copied over the old data directory, and modified the new config.php with the three values listed in the guide. All the containers are up and running, however, the Nextcloud container is running into an error. I actually restored from the initial AIO backup and ran through the steps again and still run into this same issue.
Installing imagemagick via apk...
Installing PHP build dependencies...
Installing Imagick via PECL...
Configuring Redis as session handler...
Setting php max children...
PDOException: SQLSTATE[42P01]: Undefined table: 7 ERROR:  relation "oc_appconfig" does not exist
LINE 1: SELECT * FROM "oc_appconfig"
                      ^ in /var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php:82
ace:
#0 /var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php(82): PDO->query('SELECT * FROM "...')
#1 /var/www/html/3rdparty/doctrine/dbal/src/Connection.php(1062): Doctrine\DBAL\Driver\PDO\Connection->query('SELECT * FROM "...')
#2 /var/www/html/lib/private/DB/Connection.php(261): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM "...', Array, Array, NULL)
#3 /var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(345): OC\DB\Connection->executeQuery('SELECT * FROM "...', Array, Array)
#4 /var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php(281): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/html/lib/private/AppConfig.php(415): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/html/lib/private/AppConfig.php(180): OC\AppConfig->loadConfigValues()
#7 /var/www/html/lib/private/AppConfig.php(371): OC\AppConfig->getApps()
#8 /var/www/html/lib/private/legacy/OC_App.php(965): OC\AppConfig->getValues(false, 'installed_versi...')
#9 /var/www/html/lib/private/Server.php(725): OC_App::getAppVersions()
#10 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\Server->OC\{closure}(Object(OC\Server))
#11 /var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#12 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#13 /var/www/html/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', false)
#14 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#15 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(184): OC\AppFramework\Utility\SimpleContainer->get('OC\\Memcache\\Fac...')
#16 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#17 /var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#18 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet('OCP\\ICacheFacto...')
#19 /var/www/html/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OCP\\ICacheFacto...', false)
#20 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query('OCP\\ICacheFacto...')
#21 /var/www/html/lib/private/Server.php(1119): OC\AppFramework\Utility\SimpleContainer->get('OCP\\ICacheFacto...')
#22 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\Server->OC\{closure}(Object(OC\Server))
#23 /var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#24 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#25 /var/www/html/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', false)
#26 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#27 /var/www/html/lib/private/Server.php(2070): OC\AppFramework\Utility\SimpleContainer->get('OCP\\Lock\\ILocki...')
#28 /var/www/html/lib/private/Files/View.php(117): OC\Server->getLockingProvider()
#29 /var/www/html/lib/private/Server.php(462): OC\Files\View->__construct()
#30 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\Server->OC\{closure}(Object(OC\Server))
#31 /var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#32 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#33 /var/www/html/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', false)
#34 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#35 /var/www/html/lib/private/Server.php(1472): OC\AppFramework\Utility\SimpleContainer->get('OC\\Files\\Node\\H...')
#36 /var/www/html/lib/base.php(617): OC\Server->boot()
#37 /var/www/html/lib/base.php(1144): OC::init()
#38 /var/www/html/console.php(48): require_once('/var/www/html/l...')
#39 /var/www/html/occ(11): require_once('/var/www/html/c...')
#40 {main}
Any advice for troubleshooting this? I may eventually give up and just try the user_migration app.
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'redis' =>
    'host' => 'nextcloud-aio-redis',
    'password' => 'redispassword',
    'port' => 6379,
  'overwritehost' => 'nextcloud.mydomain',
  'passwordsalt' => 'my old passwordsalt',
  'secret' => 'my old secret',
    0 => 'localhost',
    1 => 'nextcloud.mydomain',
  'datadirectory' => '/mnt/ncdata',
  'dbtype' => 'pgsql',
  'version' => '25.0.2.3',
  'overwrite.cli.url' => 'https://nextcloud.mydomain/',
  'dbname' => 'nextcloud_database',
  'dbhost' => 'nextcloud-aio-database',
  'dbuser' => 'oc_nextcloud',
  'dbpassword' => 'mydbpassword',
  'instanceid' => 'my old instanceid',
  'loglevel' => '2',
  'log_type' => 'file',
  'logfile' => '/var/www/html/data/nextcloud.log',
  'log_rotate_size' => '10485760',
  'log.condition' =>
    'apps' =>
      0 => 'admin_audit',
  'preview_max_x' => '2048',
  'preview_max_y' => '2048',
  'jpeg_quality' => '60',
  'enabledPreviewProviders' =>
    1 => 'OC\\Preview\\Image',
    2 => 'OC\\Preview\\MarkDown',
    3 => 'OC\\Preview\\MP3',
    4 => 'OC\\Preview\\TXT',
    5 => 'OC\\Preview\\OpenDocument',
    6 => 'OC\\Preview\\Movie',
  'enable_previews' => true,
  'mail_smtpmode' => 'smtp',
  'versions_retention_obligation' => 'auto, 30',
  'activity_expire_days' => '30',
  'share_folder' => '/Shared',
  'tempdirectory' => '/mnt/ncdata/tmp/',
  'one-click-instance' => true,
  'one-click-instance.user-limit' => 100,
  'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
  'files_external_allow_create_new_local' => false,
  'trusted_proxies' =>
    0 => '127.0.0.1',
    1 => '::1',
  'allow_local_remote_servers' => true,
Hi, lets handle this in Error relation "oc_appconfig" does not exist · Discussion #1553 · nextcloud/all-in-one · GitHub
