Nextcloud version : 23.0.3
Operating system : Debian 10
Apache version : 2.4.38
PHP version : 7.4.28
I have a problem : After a migration (VM and IP), my Redis is not detected by Nextcloud while my parameters is correct and is configured.
Have-you a idea the cause of the problem ?
My configuration :
Nextcloud.conf :
'instanceid' => 'oclkro4qr0g0',
'passwordsalt' => 'PASSWORD',
'secret' => 'SECRET',
0 => 'DOMAIN',
'datadirectory' => '/var/www/html/nextcloud/data',
'version' => '23.0.3.2',
'overwrite.cli.url' => 'URL',
'dbname' => 'NAME',
'dbhost' => 'HOST',
'dbport' => 'PORT',
'dbuser' => 'USER',
'dbpassword' => 'PASSWORD',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'DOMAIN',
'mail_smtphost' => 'MAIL',
'mail_smtpport' => 'PORT',
'default_phone_region' => 'FR',
'theme' => '',
'loglevel' => 2,
'redis' =>
'port' => 0,
'password' => 'PASSWORD,
'timeout' => 0,
'dbinfo' => 0,
'timeout' => 1.5,
My redis.conf :
bind 127.0.0.1 ::1
protected-mode yes
port 0
tcp-backlog 511
unixsocket /var/run/redis/redis-server.sock
unixsocketperm 770
requirepass PASSWORD
timeout 0
tcp-keepalive 300
daemonize yes
supervised no
pidfile /var/run/redis/redis-server.pid
loglevel notice
logfile /var/log/redis/redis-server.log
databases 16
always-show-logo yes
save 900 1
save 300 10
save 60 10000
stop-writes-on-bgsave-error yes
rdbcompression yes
rdbchecksum yes
dbfilename dump.rdb
dir /var/lib/redis
replica-serve-stale-data yes
replica-read-only yes
repl-diskless-sync no
repl-diskless-sync-delay 5
repl-disable-tcp-nodelay no
replica-priority 100
lazyfree-lazy-eviction no
lazyfree-lazy-expire no
lazyfree-lazy-server-del no
replica-lazy-flush no
appendonly no
appendfilename "appendonly.aof"
appendfsync everysec
no-appendfsync-on-rewrite no
auto-aof-rewrite-percentage 100
auto-aof-rewrite-min-size 64mb
aof-load-truncated yes
aof-use-rdb-preamble yes
lua-time-limit 5000
slowlog-log-slower-than 10000
slowlog-max-len 128
latency-monitor-threshold 0
notify-keyspace-events ""
hash-max-ziplist-entries 512
hash-max-ziplist-value 64
list-max-ziplist-size -2
list-compress-depth 0
set-max-intset-entries 512
zset-max-ziplist-entries 128
zset-max-ziplist-value 64
hll-sparse-max-bytes 3000
activerehashing yes
client-output-buffer-limit normal 0 0 0
client-output-buffer-limit replica 256mb 64mb 60
client-output-buffer-limit pubsub 32mb 8mb 60
hz 10
dynamic-hz yes
aof-rewrite-incremental-fsync yes
rdb-save-incremental-fsync yes
My status Redis-server :
My log Redis :
272613:M 13 Apr 2022 17:31:34.356 # Server initialized
272613:M 13 Apr 2022 17:31:34.356 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
272613:M 13 Apr 2022 17:31:34.356 # WARNING you have Transparent Huge Pages (THP) support enabled in your kernel. This will create latency and memory usage issues with Redis. To fix this issue run the command 'echo never > /sys/kernel/mm/transparent_hugepage/enabled' as root, and add it to your /etc/rc.local in order to retain the setting after a reboot. Redis must be restarted after THP is disabled.
272613:M 13 Apr 2022 17:31:34.365 * DB loaded from disk: 0.009 seconds
272613:M 13 Apr 2022 17:31:34.365 * The server is now ready to accept connections at /var/run/redis/redis-server.sock
272613:M 13 Apr 2022 17:36:35.063 * 10 changes in 300 seconds. Saving...
272613:M 13 Apr 2022 17:36:35.066 * Background saving started by pid 272735
272735:C 13 Apr 2022 17:36:35.091 * DB saved on disk
272735:C 13 Apr 2022 17:36:35.092 * RDB: 0 MB of memory used by copy-on-write
272613:M 13 Apr 2022 17:36:35.166 * Background saving terminated with success
272613:M 13 Apr 2022 17:41:36.060 * 10 changes in 300 seconds. Saving...
272613:M 13 Apr 2022 17:41:36.061 * Background saving started by pid 273003
273003:C 13 Apr 2022 17:41:36.100 * DB saved on disk
273003:C 13 Apr 2022 17:41:36.101 * RDB: 0 MB of memory used by copy-on-write
272613:M 13 Apr 2022 17:41:36.161 * Background saving terminated with success
My nextcloud.conf :
{"reqId":"FdGk8qRjRuaVRq1kqt8N","level":3,"time":"2022-04-13T17:09:17+00:00","remoteAddr":"XX.XX.XX.XX","user":"--","app":"index","method":"PUT","url":"/index.php/apps/user_status/heartbeat","message":"No such file or directory","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.84 Safari/537.36 OPR/85.0.4341.68","version":"23.0.3.2","exception":{"Exception":"RedisException","Message":"No such file or directory","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":132,"function":"pconnect","class":"Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":172,"function":"create","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Redis.php","line":46,"function":"getInstance","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Factory.php","line":120,"function":"__construct","class":"OC\\Memcache\\Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Server.php","line":1080,"function":"createLocking","class":"OC\\Memcache\\Factory","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":160,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":127,"function":"offsetGet","class":"Pimple\\Container","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/ServerContainer.php","line":136,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\ServerContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Server.php","line":2040,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":118,"function":"getLockingProvider","class":"OC\\Server","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Server.php","line":439,"function":"__construct","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":160,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":127,"function":"offsetGet","class":"Pimple\\Container","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/ServerContainer.php","line":136,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\ServerContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Server.php","line":1403,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":594,"function":"boot","class":"OC\\Server","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1087,"function":"init","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/index.php","line":34,"args":["/var/www/html/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/lib/private/RedisFactory.php","Line":132,"CustomMessage":"--"}}
{"reqId":"FdGk8qRjRuaVRq1kqt8N","level":3,"time":"2022-04-13T17:09:17+00:00","remoteAddr":"XX.XX.XX.XX","user":"--","app":"no app in context","method":"PUT","url":"/index.php/apps/user_status/heartbeat","message":"Could not boot files_trashbin: Could not resolve trashManager! Class trashManager does not exist","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.84 Safari/537.36 OPR/85.0.4341.68","version":"23.0.3.2","exception":{"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve trashManager! Class trashManager does not exist","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":131,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/ServerContainer.php","line":161,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":438,"function":"query","class":"OC\\ServerContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":57,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"function":"OC\\AppFramework\\Bootstrap\\{closure}","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"array_map"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_trashbin/lib/AppInfo/Application.php","line":56,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":181,"function":"boot","class":"OCA\\Files_Trashbin\\AppInfo\\Application","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":206,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/apps/dav/lib/AppInfo/Application.php","line":172,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":181,"function":"boot","class":"OCA\\DAV\\AppInfo\\Application","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":206,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Util.php","line":199,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/Files/Mount/Manager.php","line":87,"function":"setupRootFS","class":"OC_Util","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/Files/Mount/Manager.php","line":103,"function":"setupForFind","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":1385,"function":"find","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/Root.php","line":200,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/LazyFolder.php","line":65,"function":"call_user_func_array"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/LazyFolder.php","line":142,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/AppData/AppData.php","line":141,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/JSCombiner.php","line":96,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/JSResourceLocator.php","line":115,"function":"process","class":"OC\\Template\\JSCombiner","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/JSResourceLocator.php","line":71,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/TemplateLayout.php","line":388,"function":"find","class":"OC\\Template\\ResourceLocator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/TemplateLayout.php","line":216,"function":"findJavascriptFiles","class":"OC\\TemplateLayout","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":331,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":74,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","Line":120,"CustomMessage":"Could not boot files_trashbin: Could not resolve trashManager! Class trashManager does not exist"}}
{"reqId":"FdGk8qRjRuaVRq1kqt8N","level":3,"time":"2022-04-13T17:09:17+00:00","remoteAddr":"XX.XX.XX.XX","user":"--","app":"no app in context","method":"PUT","url":"/index.php/apps/user_status/heartbeat","message":"Could not boot files_versions: Could not resolve OCA\\Files_Versions\\Versions\\IVersionManager! Class can not be instantiated","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.84 Safari/537.36 OPR/85.0.4341.68","version":"23.0.3.2","exception":{"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve OCA\\Files_Versions\\Versions\\IVersionManager! Class can not be instantiated","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":131,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":463,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":435,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_versions/lib/AppInfo/Application.php","line":128,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_versions/lib/AppInfo/Application.php","line":115,"function":"loadBackend","class":"OCA\\Files_Versions\\AppInfo\\Application","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"registerVersionBackends","class":"OCA\\Files_Versions\\AppInfo\\Application","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_versions/lib/AppInfo/Application.php","line":100,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":181,"function":"boot","class":"OCA\\Files_Versions\\AppInfo\\Application","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":206,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/apps/dav/lib/AppInfo/Application.php","line":172,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":181,"function":"boot","class":"OCA\\DAV\\AppInfo\\Application","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":206,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Util.php","line":199,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/Files/Mount/Manager.php","line":87,"function":"setupRootFS","class":"OC_Util","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/Files/Mount/Manager.php","line":103,"function":"setupForFind","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":1385,"function":"find","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/Root.php","line":200,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/LazyFolder.php","line":65,"function":"call_user_func_array"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/LazyFolder.php","line":142,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/AppData/AppData.php","line":141,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/JSCombiner.php","line":96,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/JSResourceLocator.php","line":115,"function":"process","class":"OC\\Template\\JSCombiner","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/JSResourceLocator.php","line":71,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/TemplateLayout.php","line":388,"function":"find","class":"OC\\Template\\ResourceLocator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/TemplateLayout.php","line":216,"function":"findJavascriptFiles","class":"OC\\TemplateLayout","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":331,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":74,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","Line":116,"CustomMessage":"Could not boot files_versions: Could not resolve OCA\\Files_Versions\\Versions\\IVersionManager! Class can not be instantiated"}}
{"reqId":"FdGk8qRjRuaVRq1kqt8N","level":3,"time":"2022-04-13T17:09:17+00:00","remoteAddr":"XX.XX.XX.XX","user":"--","app":"no app in context","method":"PUT","url":"/index.php/apps/user_status/heartbeat","message":"Could not boot files_sharing: Could not resolve externalMountProvider! Class externalMountProvider does not exist","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.84 Safari/537.36 OPR/85.0.4341.68","version":"23.0.3.2","exception":{"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve externalMountProvider! Class externalMountProvider does not exist","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":131,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/ServerContainer.php","line":161,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":438,"function":"query","class":"OC\\ServerContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":57,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"function":"OC\\AppFramework\\Bootstrap\\{closure}","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"array_map"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/var/www/html/nextcloud/apps/files_sharing/lib/AppInfo/Application.php","line":104,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":181,"function":"boot","class":"OCA\\Files_Sharing\\AppInfo\\Application","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":206,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Util.php","line":199,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/Files/Mount/Manager.php","line":87,"function":"setupRootFS","class":"OC_Util","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/Files/Mount/Manager.php","line":103,"function":"setupForFind","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":1385,"function":"find","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/Root.php","line":200,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/LazyFolder.php","line":65,"function":"call_user_func_array"},{"file":"/var/www/html/nextcloud/lib/private/Files/Node/LazyFolder.php","line":142,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/AppData/AppData.php","line":141,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/JSCombiner.php","line":96,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/JSResourceLocator.php","line":115,"function":"process","class":"OC\\Template\\JSCombiner","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/JSResourceLocator.php","line":71,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/TemplateLayout.php","line":388,"function":"find","class":"OC\\Template\\ResourceLocator","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/TemplateLayout.php","line":216,"function":"findJavascriptFiles","class":"OC\\TemplateLayout","type":"::"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/legacy/OC_Template.php","line":331,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/html/nextcloud/index.php","line":74,"function":"printExceptionErrorPage","class":"OC_Template","type":"::"}],"File":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","Line":120,"CustomMessage":"Could not boot files_sharing: Could not resolve externalMountProvider! Class externalMountProvider does not exist"}}
{"reqId":"FdGk8qRjRuaVRq1kqt8N","level":3,"time":"2022-04-13T17:09:17+00:00","remoteAddr":"XX.XX.XX.XX","user":"--","app":"core","method":"PUT","url":"/index.php/apps/user_status/heartbeat","message":"No such file or directory","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.84 Safari/537.36 OPR/85.0.4341.68","version":"23.0.3.2","exception":{"Exception":"RedisException","Message":"No such file or directory","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":132,"function":"pconnect","class":"Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":172,"function":"create","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Redis.php","line":46,"function":"getInstance","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Factory.php","line":120,"function":"__construct","class":"OC\\Memcache\\Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Server.php","line":1080,"function":"createLocking","class":"OC\\Memcache\\Factory","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":160,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":127,"function":"offsetGet","class":"Pimple\\Container","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/ServerContainer.php","line":136,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\ServerContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Server.php","line":2040,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":118,"function":"getLockingProvider","class":"OC\\Server","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Server.php","line":439,"function":"__construct","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":160,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":118,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":127,"function":"offsetGet","class":"Pimple\\Container","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/ServerContainer.php","line":136,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\ServerContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Server.php","line":1403,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":594,"function":"boot","class":"OC\\Server","type":"->"},{"file":"/var/www/html/nextcloud/lib/base.php","line":1087,"function":"init","class":"OC","type":"::"},{"file":"/var/www/html/nextcloud/index.php","line":34,"args":["/var/www/html/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/lib/private/RedisFactory.php","Line":132,"CustomMessage":"--"}}
Thanking you for your help
