Nextcloud version (eg, 20.0.5): 21.0.3
Operating system and version (eg, Ubuntu 20.04): Ubuntu 18.04
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.21
PHP version (eg, 7.4): 8.0
Issue:
I get the error message that my server is not able to redirect “/ocm-provider/” and “/ocs-provider/” even by following exact the nginx configuration as described in the manual of nextcloud and other tutorials.
Is this the first time you’ve seen this error? (Y/N): Yes
The output of my config.php:
server {
listen 80;
listen [::]:80;
server_name myserver.com;
root /var/www;
location ^~ /.well-known/acme-challenge {
proxy_pass http://127.0.0.1:81;
proxy_redirect off;
# Enforce HTTPS
location / {
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
# Include SSL configuration
include /etc/nginx/snippets/ssl.conf;
# set max upload size
client_max_body_size 10G;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml $
# Include headers
include /etc/nginx/snippets/headers.conf;
root /var/www/nextcloud;
# Pagespeed is not supported by Nextcloud, so if your server is built
# with the 'ngx_pagespeed' module, uncomment this line to disable it.
#pagespeed off;
# Specify how to handle directories -- specifying '/index.php$request_uri'
# here as the fallback means that Nginx always exhibits the desired behaviour
# when a client requests a path that corresponds to a directory that exists
# on the server. In particular, if that directory contains an index.php file,
# that file is correctly served; if it doesn't, then the request is passed to
# the front-end controller. This consistent behaviour means that we don't need
# to specify custom rules for certain paths (e.g. images and other assets,
# '/updater', '/ocm-provider', '/ocs-provider'), and thus
# 'try_files $uri $uri/ /index.php$request_uri'
# always provides the desired behaviour.
index index.php index.html /index.php$request_uri;
# Rule borrowed from '.htaccess' to handle Microsoft DAV clients
location = / {
if ( $http_user_agent ~ ^DavClnt ) {
return 302 /remote.php/webdav/$is_args$args;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# Make a regex exception for '/.well-known' so that clients can still
# access it despite the existence of the regex rule
# 'location ~ /(\.|autotest|...)' which would otherwise handle requests
# for '/.well-known'.
location ^~ /.well-known {
# The following 6 rules are borrowed from '.htaccess'
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
# Anything else is dynamically handled by Nextcloud
location ^~ /.well-known { return 301 /index.php$uri; }
try_files $uri $uri/ =404;
# Rules borrowed from '.htaccess' to hide certain paths from clients
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/) { return 404; }
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) { return 404; }
# Ensure this block, which passes PHP files to the PHP process, is above the blocks
# which handle static assets (as seen below). If this block is not declared first,
# then Nginx will encounter an infinite rewriting loop when it prepends '/index.php'
# to the URI, resulting in a HTTP 500 error response.
location ~ \.php(?:$|/) {
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; # Avoid sending the security headers twice
fastcgi_param front_controller_active true; # Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
fastcgi_read_timeout 600;
fastcgi_send_timeout 600;
fastcgi_connect_timeout 600;
fastcgi_param PHP_VALUE "upload_max_filesize = 10G
post_max_size = 10G
Max_execution_time = 3600
output_buffering = off";
location ~ \.(?:css|js|svg|gif)$ {
expires 6M; # Cache-Control policy borrowed from '.htaccess'
access_log off; # Optional: Don't log access to assets
location ~ \.woff2?$ {
expires 7d; # Cache-Control policy borrowed from '.htaccess'
location / {
try_files $uri $uri/ /index.php$request_uri;
location /push/ {
proxy_pass http://localhost:7867/;
proxy_http_version 1.1;
proxy_set_header Connection "Upgrade";
proxy_set_header Host $host;
The output of my nginx conf:
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'myserver.com',
'datadirectory' => '/var/nextcloud_data',
'share_folder' => '/Mit mir geteilt',
'overwrite.cli.url' => 'https://myserver.com',
'version' => '21.0.3.1',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud_db_user',
'dbpassword' => 'xxx',
'enable_previews' => true,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\Movie',
6 => 'OC\\Preview\\PDF',
7 => 'OC\\Preview\\MP3',
8 => 'OC\\Preview\\TXT',
9 => 'OC\\Preview\\MarkDown',
'preview_max_x' => 1024,
'preview_max_y' => 768,
'preview_max_scale_factor' => 1,
'auth.bruteforce.protection.enabled' => true,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_domain' => 'myserver.com',
'mail_smtpauth' => 1,
'mail_smtphost' => 'xxx',
'mail_smtpport' => '465',
'mail_smtpname' => 'xxx',
'mail_smtppassword' => 'xxx',
'theme' => '',
'loglevel' => 2,
'twofactor_enforced' => 'false',
0 => 'Bots',
'app_install_overwrite' =>
0 => 'calendar',
'ldapIgnoreNamingRules' => false,
'updater.secret' => 'xxx',
'redis' =>
'port' => 0,
'timeout' => 0.0,
'trusted_proxies' =>
0 => '127.0.0.1',
1 => '::1',
2 => 'xxx',
