Operating system: Linux 6.12.15-production+truenas #1 SMP PREEMPT_DYNAMIC Mon Apr 14 14:41:12 UTC 2025 x86_64
Webserver: Apache/2.4.62 (Debian) (apache2handler)
Database: pgsql PostgreSQL 17.4 (Debian 17.4-1.pgdg120+2) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
PHP version: 8.3.20
Modules loaded: Core, date, libxml, openssl, pcre, sqlite3, zlib, ctype, curl, dom, fileinfo, filter, hash, iconv, json, mbstring, SPL, session, PDO, pdo_sqlite, standard, posix, random, Reflection, Phar, SimpleXML, tokenizer, xml, xmlreader, xmlwriter, mysqlnd, apache2handler, apcu, bcmath, exif, ftp, gd, gmp, igbinary, imagick, intl, ldap, memcached, pcntl, pdo_mysql, pdo_pgsql, redis, sodium, sysvsem, zip, Zend OPcache
Nextcloud version: 31.0.2 - 31.0.2.1
Updated from an older Nextcloud/ownCloud or fresh install:
- from beginning
- when trying to Sync calendar and contact with Mac OS/iOs
- docker/truenas App
- no
I Receive error „ daaccountvalidationdomain:100“ when i try to Connect calendar or contact via Profile in Mac OS/iOs
- Import Profile
- install and gibt Password
- error appears
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the Copy raw option from Administration settings->Logging screen or from your nextcloud.log
located in your data directory). Feel free to use a pastebin/gist service if necessary.
I don’t really know if this error log is relevant?
`{"reqId":"CSpKS5boFBAIcXHlkBmk","level":3,"time":"2025-04-14T16:50:53+00:00","remoteAddr":"fdd0:0:0:1::5","user":false,"app":"core","method":"GET","url":"/apps/dashboard/","message":"Renewing session token failed: Token does not exist: token does not exist","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.3.1 Safari/605.1.15","version":"31.0.2.1","exception":{"Exception":"OC\\Authentication\\Exceptions\\InvalidTokenException","Message":"Token does not exist: token does not exist","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenProvider.php","line":232,"function":"getToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/public/AppFramework/Db/TTransactional.php","line":45,"function":"OC\\Authentication\\Token\\{closure}","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenProvider.php","line":231,"function":"atomic","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":[{"__class__":"Closure"},{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/Authentication/Token/Manager.php","line":155,"function":"renewSessionToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***","9d3553f0b744d0d208e4bd9dac88cbb8"]},{"file":"/var/www/html/lib/private/User/Session.php","line":884,"function":"renewSessionToken","class":"OC\\Authentication\\Token\\Manager","type":"->","args":["*** sensitive parameters replaced ***","9d3553f0b744d0d208e4bd9dac88cbb8"]},{"file":"/var/www/html/lib/base.php","line":1107,"function":"loginWithCookie","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/base.php","line":1014,"function":"handleLogin","class":"OC","type":"::","args":[{"__class__":"OC\\AppFramework\\Http\\Request"}]},{"file":"/var/www/html/index.php","line":24,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenProvider.php","Line":165,"Previous":{"Exception":"OCP\\AppFramework\\Db\\DoesNotExistException","Message":"token does not exist","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenProvider.php","line":157,"function":"getToken","class":"OC\\Authentication\\Token\\PublicKeyTokenMapper","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenProvider.php","line":232,"function":"getToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/public/AppFramework/Db/TTransactional.php","line":45,"function":"OC\\Authentication\\Token\\{closure}","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenProvider.php","line":231,"function":"atomic","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":[{"__class__":"Closure"},{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/Authentication/Token/Manager.php","line":155,"function":"renewSessionToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***","9d3553f0b744d0d208e4bd9dac88cbb8"]},{"file":"/var/www/html/lib/private/User/Session.php","line":884,"function":"renewSessionToken","class":"OC\\Authentication\\Token\\Manager","type":"->","args":["*** sensitive parameters replaced ***","9d3553f0b744d0d208e4bd9dac88cbb8"]},{"file":"/var/www/html/lib/base.php","line":1107,"function":"loginWithCookie","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/base.php","line":1014,"function":"handleLogin","class":"OC","type":"::","args":[{"__class__":"OC\\AppFramework\\Http\\Request"}]},{"file":"/var/www/html/index.php","line":24,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenMapper.php","Line":81},"message":"Renewing session token failed: Token does not exist: token does not exist","user":"peter","exception":[],"CustomMessage":"Renewing session token failed: Token does not exist: token does not exist"},"id":"680290efe61f3"}
No log available?
"htaccess.RewriteBase": "\/",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"redis": {
"port": 6379
"overwriteprotocol": "https",
"upgrade.disable-web": true,
"dbtype": "pgsql",
"version": "31.0.2.1",
"overwrite.cli.url": "https:\/\/localhost",
"dbport": "",
"default_phone_region": "DE",
"mail_smtpmode": "smtp",
"mail_smtpauth": true,
"mail_sendmailmode": "smtp",
"mail_smtpport": "587",
"app_install_overwrite": [],
"loglevel": 2,
"127.0.0.1",
"192.168.178.6",
"localhost",
"next.lang-w.de",
"nextcloud"
The output of occ app:list
(if possible).
I think the Redirect does not work correct. In i try to Access https://next.mydomain.com/.well-Known/caldav i receive an Error:
https://next.mydomain.com:30027/.well-known/caldav (Safari can’t access this domain)
Access to https://next.mydomain.com/remote.php/dav results in the expected way:
This is the WebDAV interface. It can only be accessed by WebDAV clients such as the Nextcloud desktop sync client.
Nextcloud is installed on a truenas System as an App on Port 30027. Access via App and web is working.
Nginx Proxy Manager is installed and working (Access via web-interface possible.
(NPM is installed also on truenas as an App)
And hints how to debug this Situation?
I am Reading since the beginning of this year Manuals and Tutorials and don‘t find the Error. Even after several new installs of truenas and Nextcloud.
