example
longer
example
here
Nextcloud version (eg, 18.0.2): 19.0.1snap3
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.1
Apache or nginx version (eg, Apache 2.4.25): N/A(Caddy v2.1.1)
PHP version (eg, 7.1): Not Sure
Trying to find a good way to set up Collabora Online for my personal Nextcloud instance. It says “Collabora Online server is reachable.” in settings, but when I try to open a document it gives the “Connection to server lost” error.
Is this the first time you’ve seen this error? (Y/N): Yes
- N/A
- N/A
- N/A
N/A
No convenient way to paste, will add if requested
N/A, will add if requested
