I am planning to set up a Nextcloud with Collabora for a small business, 120 accounts but maximum 25 are used at the same time, currently ~130GB, mostly used for office files, but also 40GB of fotos and videos, will probably set up storage space of 200GB or 300GB. We will also use Talk, with the High Performance Backend from www.struktur.de
Do you have suggestions for:
-> how many cores?
-> how much RAM?
-> is cpu or ram more important?
I am planning to use vps cloud from https://cloudamo.com/store/nextcloud and there I have to select number of cpus and ram… Their support did not give me a helpful answer…
Yes I saw this https://docs.nextcloud.com/server/latest/admin_manual/installation/system_requirements.html but that is minumum requirements - I would like to know what I need to make it run smoothely.
Thank you!
