[core] Fout: Error: Object of class OC\DB\QueryBuilder\QueryBuilder could not be converted to string at <>
- /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/Expression/CompositeExpression.php line 170
implode() - /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php line 1328
Doctrine\DBAL\Query\Expression\CompositeExpression->__toString() - /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php line 390
Doctrine\DBAL\Query\QueryBuilder->getSQLForSelect() - /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php line 345
Doctrine\DBAL\Query\QueryBuilder->getSQL() - /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php line 281
Doctrine\DBAL\Query\QueryBuilder->execute() - /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php line 294
OC\DB\QueryBuilder\QueryBuilder->execute() - /var/www/nextcloud/lib/public/AppFramework/Db/QBMapper.php line 336
OC\DB\QueryBuilder\QueryBuilder->executeQuery() - /var/www/nextcloud/apps/passwords/lib/Db/PasswordMapper.php line 86
OCP\AppFramework\Db\QBMapper->findEntities() - /var/www/nextcloud/apps/passwords/lib/Services/Object/PasswordService.php line 79
OCA\Passwords\Db\PasswordMapper->findAllOrphanedTargetPasswords(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/apps/passwords/lib/Cron/SynchronizeShares.php line 143
OCA\Passwords\Services\Object\PasswordService->findOrphanedTargetPasswords(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/apps/passwords/lib/Cron/SynchronizeShares.php line 110
OCA\Passwords\Cron\SynchronizeShares->deleteOrphanedTargetPasswords(“*** sensitive parameters replaced ***”) - /var/www/nextcloud/apps/passwords/lib/Cron/AbstractTimedJob.php line 74
OCA\Passwords\Cron\SynchronizeShares->runJob() - /var/www/nextcloud/lib/private/BackgroundJob/Job.php line 54
OCA\Passwords\Cron\AbstractTimedJob->run() - /var/www/nextcloud/lib/private/BackgroundJob/TimedJob.php line 60
OC\BackgroundJob\Job->execute() - /var/www/nextcloud/cron.php line 152
OC\BackgroundJob\TimedJob->execute()
at 2023-01-16T14:55:03+00:00
Recognize job waiting for 25 hours
Nc 25
Ubuntu 24
