32.0.8
- Linux raspberrypi 6.12.62+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.62-1+rpt1~bookworm (2026-01-19) aarch64 GNU/Linux
aio?
aio?
- PHP version (e.g, 8.3):
aio?
Yes
Upon installation of the Recognize app
AIO
no
Configuration of the Recognize app complains that “Could not execute the Node.js binary. You may need to set the path to a working binary manually.”
Since I found other topics in the forum where people reported this same issue, but without a “reproducible” resolution, I tried to figure out what is wrong with the node executable in the container. I found that it seems to rely on a shared library not present on my system:
$ sudo docker exec --user www-data -it nextcloud-aio-nextcloud bash
nextcloud-aio-nextcloud:/var/www/html$ pwd
/var/www/html
nextcloud-aio-nextcloud:/var/www/html$ df
Filesystem 1K-blocks Used Available Use% Mounted on
overlay 245576260 118517824 114565556 51% /
tmpfs 65536 0 65536 0% /dev
shm 65536 0 65536 0% /dev/shm
/dev/nvme0n1p2 245576260 118517824 114565556 51% /mnt/ncdata
/dev/sdb1 492266400 15159304 452028064 4% /mnt/ncdata/rob/files/Photos
tmpfs 4126240 0 4126240 0% /proc/asound
tmpfs 4126240 0 4126240 0% /sys/firmware
nextcloud-aio-nextcloud:/var/www/html$ find / -name node
find: /run/sudo: Permission denied
find: /root: Permission denied
find: /etc/sudoers.d: Permission denied
/sys/devices/system/node
/sys/bus/node
/usr/bin/node
find: /var/lib/sudo: Permission denied
find: /var/lib/samba/private: Permission denied
find: /var/lib/samba/bind-dns: Permission denied
/var/www/html/custom_apps/recognize/bin/node
^C
nextcloud-aio-nextcloud:/var/www/html$ ls -l /var/www/html/custom_apps/recognize/bin/node
-rwxr-xr-x 1 www-data www-data 95453208 Apr 6 13:24 /var/www/html/custom_apps/recognize/bin/node
nextcloud-aio-nextcloud:/var/www/html$ file !$
file /var/www/html/custom_apps/recognize/bin/node
bash: file: command not found
nextcloud-aio-nextcloud:/var/www/html$ /var/www/html/custom_apps/recognize/bin/node -v
bash: /var/www/html/custom_apps/recognize/bin/node: cannot execute: required file not found
nextcloud-aio-nextcloud:/var/www/html$ ldd /var/www/html/custom_apps/recognize/bin/node
/lib/ld-linux-aarch64.so.1 (0x7ffef5fc0000)
libdl.so.2 => /lib/ld-linux-aarch64.so.1 (0x7ffef5fc0000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x7ffef5cf8000)
libm.so.6 => /lib/ld-linux-aarch64.so.1 (0x7ffef5fc0000)
libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x7ffef5cc4000)
libpthread.so.0 => /lib/ld-linux-aarch64.so.1 (0x7ffef5fc0000)
libc.so.6 => /lib/ld-linux-aarch64.so.1 (0x7ffef5fc0000)
Error loading shared library ld-linux-aarch64.so.1: No such file or directory (needed by /var/www/html/custom_apps/recognize/bin/node)
Error relocating /var/www/html/custom_apps/recognize/bin/node: fcntl64: symbol not found
Error relocating /var/www/html/custom_apps/recognize/bin/node: __register_atfork: symbol not found
Error relocating /var/www/html/custom_apps/recognize/bin/node: __getauxval: symbol not found
Error relocating /var/www/html/custom_apps/recognize/bin/node: makecontext: symbol not found
Error relocating /var/www/html/custom_apps/recognize/bin/node: backtrace: symbol not found
Error relocating /var/www/html/custom_apps/recognize/bin/node: getcontext: symbol not found
Error relocating /var/www/html/custom_apps/recognize/bin/node: setcontext: symbol not found
Error relocating /var/www/html/custom_apps/recognize/bin/node: backtrace_symbols: symbol not found
Error relocating /var/www/html/custom_apps/recognize/bin/node: gnu_get_libc_version: symbol not found
Error relocating /var/www/html/custom_apps/recognize/bin/node: __libc_stack_end: symbol not found
nextcloud-aio-nextcloud:/var/www/html$ ls -l /lib/ld-*
-rwxr-xr-x 1 root root 723480 Oct 13 20:32 /lib/ld-musl-aarch64.so.1
exit
could not identify any relevant items through manual inspection of the log.
n.a.
not relevant?
"one-click-instance": true,
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"redis": {
"port": 6379
"overwritehost": "***REMOVED SENSITIVE VALUE***",
"overwriteprotocol": "https",
"localhost",
"dbtype": "pgsql",
"version": "32.0.8.2",
"overwrite.cli.url": "https:\/\/nextcloud.hooft.net\/",
"dbport": "",
"loglevel": 2,
"log_type": "file",
"log_rotate_size": 10485760,
"log.condition": {
"apps": [
"admin_audit"
"preview_max_x": 2048,
"preview_max_y": 2048,
"jpeg_quality": 60,
"enabledPreviewProviders": [
"OC\\Preview\\MarkDown",
"OC\\Preview\\MP3",
"OC\\Preview\\TXT",
"OC\\Preview\\OpenDocument",
"OC\\Preview\\Movie",
"OC\\Preview\\Krita",
"OC\\Preview\\ImaginaryPDF",
"OC\\Preview\\HEIC",
"OC\\Preview\\Image",
"OC\\Preview\\TIFF"
"enable_previews": true,
"upgrade.disable-web": true,
"mail_smtpmode": "smtp",
"activity_expire_days": 30,
"share_folder": "\/Shared",
"htaccess.RewriteBase": "\/",
"dbpersistent": false,
"mail_smtpauth": 1,
"mail_sendmailmode": "smtp",
"mail_smtpsecure": "ssl",
"mail_smtpport": "465",
"default_phone_region": "NL",
"updatechecker": false,
"memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-aarch64-musl",
"memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-aarch64",
"DOMAIN": "***REMOVED SENSITIVE VALUE***",
"AIO_VERSION": "v12.9.2"
- activity: 5.0.0
- admin_audit: 1.22.0
- assistant: 2.13.0
- bruteforcesettings: 5.0.0
- calendar: 6.2.2
- circles: 32.0.0
- comments: 1.22.0
- contacts: 8.3.7
- contactsinteraction: 1.13.1
- cookbook: 0.11.6
- dashboard: 7.12.0
- dav: 1.34.2
- deck: 1.16.3
- federation: 1.22.0
- files: 2.4.0
- files_downloadlimit: 5.0.0
- files_pdfviewer: 5.0.0
- files_reminders: 1.5.0
- files_sharing: 1.24.1
- files_trashbin: 1.22.0
- files_versions: 1.25.0
- firstrunwizard: 5.0.0
- integration_openai: 3.10.1
- logreader: 5.0.0
- mail: 5.7.7
- memories: 7.8.2
- news: 28.1.0
- nextcloud-aio: 0.8.0
- nextcloud_announcements: 4.0.0
- notes: 4.13.1
- notifications: 5.0.0
- notify_push: 1.3.1
- oauth2: 1.20.0
- password_policy: 4.0.0
- photos: 5.0.0
- previewgenerator: 5.13.0
- privacy: 4.0.0
- profile: 1.1.0
- provisioning_api: 1.22.0
- recognize: 10.0.7
- recommendations: 5.0.0
- related_resources: 3.0.0
- richdocuments: 9.0.5
- richdocumentscode_arm64: 25.4.904
- serverinfo: 4.0.0
- settings: 1.15.1
- sharebymail: 1.22.0
- spreed: 22.0.11
- support: 4.0.0
- survey_client: 4.0.0
- systemtags: 1.22.0
- tables: 1.0.5
- tasks: 0.17.1
- text: 6.0.1
- theming: 2.7.0
- twofactor_totp: 14.0.0
- updatenotification: 1.22.0
- user_status: 1.12.0
- viewer: 5.0.0
- weather_status: 1.12.0
- webhook_listeners: 1.3.0
- whiteboard: 1.5.7
- workflowengine: 2.14.0
- app_api: 32.0.0 (installed 4.0.5)
- encryption: 2.20.0
- files_external: 1.24.1
- suspicious_login: 10.0.0
- twofactor_nextcloud_notification: 6.0.0
- user_ldap: 1.23.0
