I want to put a directory of documents for my clients. I am looking for a solution to put a directory read-only. Is it possible ?
Is it also possible to prevent the deletion of files in a directory?
Thank you
Nicolas
Thank you
Nicolas
2 ways, for both you create a folder with the files in your account, then
When you share a folder, you can set the permissions.
Thank you tflidd ! It’s OK.
