Maintenance releases are coming, help us with testing
Maintenance releases 22.2.6 and 23.0.3 are coming and RCs are now available on our download server.
Many issues have been already resolved. If you experienced bugs in the previous releases, see if theyâre fixed and report any additional ones you might encounter.
Downloads
https://download.nextcloud.com/server/prereleases/nextcloud-23.0.3rc1.tar.bz2
https://download.nextcloud.com/server/prereleases/nextcloud-22.2.6rc1.tar.bz2
Changelog
23.0.3
- Allow writing audit log to syslog and systemdlog (server#30852)
- Allow to disable AuthToken v1 (server#30949)
- Add primary key for ratelimit table (server#30965)
- Bump samba images in tests (server#30967)
- Update variables.scss - Fallback font before Noto Color Emoji (server#30969)
- Show if the mail server settings are not set or verified (server#30998)
- Use the unjailed-path in OC_Helper::getStorageInfo() for files located in SharedStorage. (server#30999)
- Fix: Birthday events missing after reimporting contacts (server#31000)
- Bump clipboard from 2.0.9 to 2.0.10 (server#31023)
- Fix bugs with incorrect currentFileList in the favorite and share by you view (server#31050)
- Allow specify a config prefix for another database connection (server#31059)
- Donât provide favorite activity settings (server#31084)
- Only setup part of the filesystem for appdata requests (server#31098)
- Allow sub-admins to access delegated settings. (server#31102)
- Ignore contact interaction with self (server#31120)
- Fix overlapping buttons in apps-management (server#31179)
- Fix typo in DAV namespace registration (server#31183)
- Fix a broken tooltip (server#31184)
- Improve user status revert performance (server#31192)
- Fix path handling when transferring incoming shares (server#31204)
- Bump dompurify from 2.3.5 to 2.3.6 (server#31226)
- Improve caching policy use immutable when loading versionned assets (server#31244)
- Hide download button for images (server#31253)
- Donât redirect when loading files index page (server#31255)
- Consider only reminders with calendar data (server#31262)
- Also cache non-existing to reuse it (server#31297)
- Ignore cache in occ ldap:check-ldap command (server#31299)
- Wrap S3 multipart upload exception (server#31302)
- Fix ldap:check-user method for newly created LDAP users (server#31306)
- Avoid PHP errors in the checkers drone step (server#31313)
- Background job time windows (server#31318)
- Mark split database configs as sensitive (server#31331)
- Update CRL after revocation of rocket_integration.csr (server#31350)
- Bump backbone from 1.4.0 to 1.4.1 (server#31369)
- Make Sabre File exception messages translatable (server#31392)
- Censor more configs (server#31399)
- Donât set up full filesystem to check for certificates (server#31401)
- Also use hashed/indexed column on delete (server#31402)
- Fix caching of the user avatar (server#31410)
- Fix duplicate primary email message (server#31412)
- Fix developer link (server#31423)
- Fix fileactions for sharing overview (server#31424)
- Prevent default right-click options when hideDownload is enabled (server#31427)
- Fix return type of avatar file (server#31432)
- Fix âNextcloud is not allowed to use the OPcache APIâ warning (server#31437)
- Add Nextcloud docs link to OPcache recommends (server#31438)
- Be conservative when reading from fresh created column (server#31442)
- Init userâs file system if not existing on ownership transfer (server#31445)
- Use persistent connections when connecting to redis (server#31450)
- Fix settings error message timeout (server#31457)
- Connectivity check: allow using the protocol in âconnectivity_check_domainsâ (server#31479)
- Add option to disallow creation of local storages (server#31481)
- Fix too many file download notifications when watching a video (server#31485)
- Fix new file menu (server#31490)
- Try to reduce the load from writing (activity#731)
- Allow specify a config prefix for another database connection (activity#735)
- Adjust nextcloud lib version (activity#739)
- Make background job time insensitive (activity#741)
- Fix cached circle returning bool before being parsed as JSON (circles#932)
- MembershipsService â membershipService (circles#934)
- Block/force circle types (circles#938)
- Set member as INVITED only if not external (circles#940)
- Allow configuration of one single password per circle (circles#944)
- Display spent time on request (circles#949)
- Only refresh notifications once with notify push (notifications#1155)
- Improve mass notification processing (notifications#1156)
- Bump url-parse from 1.5.4 to 1.5.10 (photos#1043)
- Fix privacy UI with subscription (privacy#707)
- Bump vue-loader from 15.9.6 to 15.9.8 (privacy#712)
- Bump @nextcloud/babel-config from 1.0.0-beta.1 to 1.0.0 (privacy#715)
- Bump @babel/core from 7.13.15 to 7.13.16 (privacy#718)
- Bump eslint-import-resolver-webpack from 0.13.0 to 0.13.2 (privacy#721)
- Bump babel-loader from 8.2.2 to 8.2.3 (privacy#724)
- Bump sass from 1.32.10 to 1.32.13 (privacy#731)
- Bump vue and vue-template-compiler (privacy#732)
- Bump eslint-config-standard from 16.0.2 to 16.0.3 (privacy#733)
- Bump node-polyfill-webpack-plugin from 1.1.0 to 1.1.4 (privacy#734)
- Bump eslint-webpack-plugin from 2.5.3 to 2.5.4 (privacy#738)
- Add index for last_contact in text_sessions table (text#2147)
- Use file.path to track EditorWrapper instances more accurately (text#2150)
- Build(deps): bump prosemirror-transform from 1.3.3 to 1.3.4 (text#2159)
- Fix: only apply bullet style to ul > li (text#2195)
- Build(deps): bump prosemirror-view from 1.23.6 to 1.23.7 (text#2207)
- Fix: update psalm baseline to account for changes in server (text#2208)
- Derpgon cz fix/stable23/image data urls (text#2210)
- Display content first and then load menus (text#2228)
- Build(deps-dev): bump @babel/plugin-proposal-class-properties from 7.16.0 to 7.16.7 (viewer#1171)
- Build(deps-dev): bump @nextcloud/webpack-vue-config from 4.1.0 to 4.1.4 (viewer#1174)
- Build(deps): bump camelcase from 6.2.0 to 6.2.1 (viewer#1175)
- Build(deps): bump @nextcloud/event-bus from 2.1.0 to 2.1.1 (viewer#1176)
- Build(deps-dev): bump @cypress/browserify-preprocessor from 3.0.1 to 3.0.2 (viewer#1178)
- Build(deps-dev): bump @nextcloud/eslint-config from 6.1.0 to 6.1.2 (viewer#1179)
- Build(deps-dev): bump wait-on from 6.0.0 to 6.0.1 (viewer#1180)
22.2.6
- Fix removing remote shares when the remote server is unreachable (server#29565)
- Allow writing audit log to syslog and systemdlog (server#30851)
- Allow to disable AuthToken v1 (server#30958)
- Add primary key for ratelimit table (server#30966)
- Update variables.scss - Fallback font before Noto Color Emoji (server#30968)
- Fix: Birthday events missing after reimporting contacts (server#31002)
- Bump clipboard from 2.0.9 to 2.0.10 (server#31025)
- Fix bugs with incorrect currentFileList in the favorite and share by you view (server#31051)
- Allow specify a config prefix for another database connection (server#31060)
- Donât provide favorite activity settings (server#31085)
- Ignore contact interaction with self (server#31119)
- Background job time windows (server#31122)
- Use the unjailed-path in OC_Helper::getStorageInfo() for files located in SharedStorage. (server#31136)
- Fix typo in DAV namespace registration (server#31182)
- Fix a broken tooltip (server#31185)
- Fix path handling when transferring incoming shares (server#31203)
- Fix overlapping buttons in apps-management (server#31210)
- Improve caching policy use immutable when loading versionned assets (server#31243)
- Hide download button for images (server#31254)
- Donât redirect when loading files index page (server#31256)
- Consider only reminders with calendar data (server#31263)
- Also cache non-existing to reuse it (server#31298)
- Fix ldap:check-user method for newly created LDAP users (server#31305)
- Ignore cache in occ ldap:check-ldap command (server#31307)
- Avoid PHP errors in the checkers drone step (server#31314)
- Update CRL after revocation of rocket_integration.csr (server#31351)
- Bump backbone from 1.4.0 to 1.4.1 (server#31370)
- Censor more configs (server#31400)
- Also use hashed/indexed column on delete (server#31403)
- Fix caching of the user avatar (server#31411)
- Fix duplicate primary email message (server#31413)
- Prevent default right-click options when hideDownload is enabled (server#31428)
- Fix return type of avatar file (server#31433)
- Fix developer link (server#31440)
- Fix fileactions for sharing overview (server#31441)
- Be conservative when reading from fresh created column (server#31443)
- Init userâs file system if not existing on ownership transfer (server#31446)
- Use persistent connections when connecting to redis (server#31451)
- Fix settings error message timeout (server#31458)
- Connectivity check: allow using the protocol in âconnectivity_check_domainsâ (server#31480)
- Add option to disallow creation of local storages (server#31482)
- Fix too many file download notifications when watching a video (server#31486)
- Fix new file menu (server#31497)
- Bump aws/aws-sdk-php from 3.184.6 to 3.212.2 (3rdparty#1005)
- Make background job time insensitive (activity#730)
- Allow specify a config prefix for another database connection (activity#736)
- Adjust nextcloud lib version (activity#740)
- Fix cached circle returning bool before being parsed as JSON (circles#933)
- MembershipsService â membershipService (circles#935)
- Block/force circle types (circles#937)
- Set member as INVITED only if not external (circles#939)
- Allow configuration of one single password per circle (circles#945)
- Display spent time on request (circles#948)
- Bump url-parse from 1.5.4 to 1.5.10 (photos#1044)
- Fix privacy UI with subscription (privacy#710)
- Bump sass from 1.32.10 to 1.32.13 (privacy#714)
- Bump eslint-webpack-plugin from 2.5.3 to 2.5.4 (privacy#717)
- Bump @nextcloud/babel-config from 1.0.0-beta.1 to 1.0.0 (privacy#723)
- Bump @babel/core from 7.13.15 to 7.13.16 (privacy#726)
- Bump babel-loader from 8.2.2 to 8.2.3 (privacy#727)
- Bump eslint-config-standard from 16.0.2 to 16.0.3 (privacy#728)
- Bump vue and vue-template-compiler (privacy#729)
- Bump @nextcloud/vue from 2.6.5 to 2.6.9 (privacy#730)
- Bump node-polyfill-webpack-plugin from 1.1.0 to 1.1.4 (privacy#737)
- Add index for last_contact in text_sessions table (text#2148)
- Use file.path to track more accurately EditorWrapper instances (text#2151)
- Build(deps): bump prosemirror-transform from 1.3.3 to 1.3.4 (text#2160)
- Fix: only apply bullet style to ul > li (text#2197)
- Fix: dependabot template comment (text#2212)
