Is it possible to access the files without javascript? I need to read out .json/.txt and the files in a folder. Its for an app, but i had probles with doing it directly over apache, maybe it is possible with nextcloud?
You can access all nextcloud files via the WebDav protocol
@devnull Tried it, but it works only with files, need the content of a folder too.
Thnaks for the fast help
Sorry. Does not work with directories.
But i think you can also not use WebDAV in the browser.
Maybe any other ideas?
You can set up another virtual host (e.g. in apache2) and map it to the folder:
/var/www/html/nextcloud/data/username/files
Then allow directory reading.
Options +Indexes
I already had a setup like this, but fail2ban banned the ip after some reloads of the link and i have no clue how to avoid that. But i’d like to keep the apache check enabled.
Perhaps you can whitelist the ip: https://www.fail2ban.org/wiki/index.php/Whitelist
Also you can allow the subdir only from one ip in apache2.
Sorry i do not use fail2ban.
Different ip’s
Okay, i found the solution…
<Directory /var/www/vhosts/domain.de/httpdocs/launcher/>
Options +Indexes
Allow from All <—
Satisfy Any <—
These two are needed. But at least i got an nice Cloudservice Just some small errors ill have to fix
