After my instalation self updated a few days back it does not allow any writes reporting quota is being exceeded.
I used to have quotas set for the users like 1T or 500G. But those are now gone and show as zero with a red bar. Editing the user quota in the Users page has no effect. It allows me to edit the value, enter a new value (that shows the bar in blue) and apply the update. But refreshing the page show quotas as zero again.
The errors messages are like “Upload of 11kB exceeds the quota for the folder directory…”.
I have several TB of space available and restarting the machine also did not solve the problem.
Any suggestions?
Nextcloud version: 24.0.7
Operating system and version : Linux 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l (raspberry pi)
Apache or nginx version: Could not find…
PHP version: 8.0.25
Database: mysql 8.0.31
It is huge, but here are a few lines (I filtered for errors and warnings only, let a few Info only):
Info no app in context Symfony\Component\Routing\Exception\RouteNotFoundException: Unable to generate a URL for the named route "ocs.password_policy.API.validate" as such route does not exist. 19 minutes ago
Info no app in context Symfony\Component\Routing\Exception\RouteNotFoundException: Unable to generate a URL for the named route "ocs.password_policy.API.generate" as such route does not exist. 19 minutes ago
Warning core Login failed: 'edevaldo' (Remote IP: '192.168.1.1') an hour ago
Fatal webdav Sabre\DAV\Exception\InsufficientStorage: Insufficient space in ****, 406542 required, 0 available 6 hours ago
Fatal webdav Sabre\DAV\Exception\InsufficientStorage: Insufficient space in ****, 11675 required, 0 available 10 hours ago
Fatal webdav Sabre\DAV\Exception\InsufficientStorage: Insufficient space in ****, 1025294 required, 0 available 19 hours ago
Fatal webdav Sabre\DAV\Exception\InsufficientStorage: Insufficient space in ****, 406542 required, 0 available a day ago
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
'url' => '/extra-apps',
'writable' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'instanceid' => ****
'passwordsalt' => ****
'secret' => ****
0 => ****
1 => ****
2 => ****
3 => ****
4 => ****
'datadirectory' => '/media/nextdata',
'version' => '24.0.7.1',
'overwrite.cli.url' => ****
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => 'nextcloud',
'dbpassword' => ****
'theme' => '',
'loglevel' => 0,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => ****
'mail_domain' => ****
'mail_smtphost' => ****
'mail_smtpport' => ****
'mail_smtpauth' => 1,
'mail_smtpname' => ****
'mail_smtppassword' => ****
could not find it yet....
PASTE HERE
