Hi
I am facing new issues currently and I came back to Jason’s tuto to check whether has changed on my installation since I used it.
https://bayton.org/docs/nextcloud/installing-nextcloud-on-ubuntu-16-04-lts-with-redis-apcu-ssl-apache/
I have then 2 questions
- let’s encrypt : I found a much simpler way to install it at https://www.digitalocean.com/community/tutorials/how-to-secure-apache-with-let-s-encrypt-on-ubuntu-16-04 . What do you think ? Should I stick to Jason’s way or is this one very valid as well ?
- ACPU/Redis : about 1 year ago, Jason recommended to add (among some other things) the following line in /var/www/nextcloud/config/config.php :
'memcache.local' => '\OC\Memcache\APCu',
While going through it again today, this line has been change by
What is the reason and the consequence ?
Thanks !
Kris
