Question on rotating external backup drives with nextcloud AIO using borg
I have a question in regards to backing up AIO using work backup with multiple external USB drives. Basically I’d like to have two or more external USB drives and rotate through them so each time I do a backup I plug in a different USB drive. Is this supported with the built-in Borg backup system? If so, how do I make it work?
Can I back up to multiple, swapped backup targets?
It is possible to swap your backup disks if each backup medium is assigned its own repository by creating a new one with borg init.
Source
I don’t use AIO with borg, so unfortunatly I don’t know if it is possible.
I’ve seen this. I’m hoping someone has knowledge of the aio options.
No, this is not possible with AIO afaik.
You could instead do this: GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance. · GitHub
