Hi!
I have NC 21 installed in Docker (on Debian Buster), and currently writing custom flow script, it should create PDF from a given file. Unfortunately, due to some limits of built-in standard features I have to design my own script.
I added custom flow script, based on Tag assignment: “ok” tag assigned to a file - run script
/opt/CalcSheet2pdf.sh -f %n -o %o
Right now (for debug purposes) this script simply outputs line with date to the log file, and does NOTHING else. I can login into docker container, and run this script from within the Bash shell, it outputs log file in /var/log (where I can navigate within docker). So script’s syntax is OK, its “x” permissions are for everyone.
However, when I assign tag “ok” in NC Web, I can’t find any trace of this script ever luanched. No logs in /var/log in Docker container, and no logs in /var/cloud_data within Docker’s host OS (where NC log file lives).
cat nextcloud.log | grep Calc
results nothing.
Any idea what went wrong?
Thanks in advance.
