Nextcloud version: 13.0.4
Operating system and version: OpenSuSE Leap 15
Apache or nginx version: Apache 2.4.33
PHP version: 7.2.5
Push notifications work of web/desktop clients, but not on Android. I originally reported this to the NextCloud Talk app, but Mario suggested it was a problem with the server or server configuration.
When I first install & register the app a message briefly appears saying “push notifications disabled”.
Around that time, there are many next cloud log messages, which all look OK to my untrained eye, but one in the apache log may be pivotal is:
- uuuuu [27/Jun/2018:14:07:20 +1000] “POST /ocs/v2.php/apps/notifications/api/v2/push?proxyServer=https://push-notifications.nextcloud.com&devicePublicKey=-----BEGIN%20PUBLIC%20KEY----------END%20PUBLIC%20KEY-----%0A&pushTokenHash= < LOTS OF HEX > &format=json HTTP/1.1” 400 112
The result code of 400 is presumably a problem.
Is this the first time you’ve seen this error?: N
- Install NC, install talk app (in NC),
- install NextCloud Talk Android app (fresh install) on phone
- start android app, specify server, register -> Message appears briefly.
In the nextcloud logs I see two “login attempt” messages, followed by one “login success” message around the time of the above 400 result; both attempts are from the same device at the same time.
This double-attempt seems to happen always.
{"reqId":"BX8jTwZaqnztBkj6768r","level":1,"time":"2018-06-27T04:07:19+00:00","remoteAddr":"xxx.yyy.zzz.ttt","user":"--","app":"admin_audit","method":"GET","url":"\/ocs\/v2.php\/apps\/spreed\/api\/v1\/room","message":"Login attempt: \"<USER>\"","userAgent":"Mozilla\/5.0 (Android) Nextcloud-Talk v2.0.2","version":"13.0.4.0"}
{"reqId":"BX8jTwZaqnztBkj6768r","level":1,"time":"2018-06-27T04:07:19+00:00","remoteAddr":"xxx.yyy.zzz.ttt","user":"<USER>","app":"admin_audit","method":"GET","url":"\/ocs\/v2.php\/apps\/spreed\/api\/v1\/room","message":"Login successful: \"<user>\"","userAgent":"Mozilla\/5.0 (Android) Nextcloud-Talk v2.0.2","version":"13.0.4.0"}
{"reqId":"Stv8fPiRNCXgkmur26EU","level":1,"time":"2018-06-27T04:07:20+00:00","remoteAddr":"xxx.yyy.zzz.ttt","user":"--","app":"admin_audit","method":"POST","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v2\/push?proxyServer=https:\/\/push-notifications.nextcloud.com&devicePublicKey=-----BEGIN%20PUBLIC%20KEY----- < STUFF > ----END%20PUBLIC%20KEY-----%0A&pushTokenHash= < TOKEN > & format=json","message":"Login attempt: \"<USER>\"","userAgent":"Mozilla\/5.0 (Android) Nextcloud-Talk v2.0.2","version":"13.0.4.0"}
{"reqId":"Stv8fPiRNCXgkmur26EU","level":1,"time":"2018-06-27T04:07:20+00:00","remoteAddr":"xxx.yyy.zzz.ttt","user":"--","app":"admin_audit","method":"POST","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v2\/push?proxyServer=https:\/\/push-notifications.nextcloud.com&devicePublicKey=-----BEGIN%20PUBLIC%20KEY--- < STUFF > ---END%20PUBLIC%20KEY-----%0A&pushTokenHash= < TOKEN > &format=json","message":"Login attempt: \"<USER>\"","userAgent":"Mozilla\/5.0 (Android) Nextcloud-Talk v2.0.2","version":"13.0.4.0"}
{"reqId":"Stv8fPiRNCXgkmur26EU","level":1,"time":"2018-06-27T04:07:20+00:00","remoteAddr":"xxx.yyy.zzz.ttt","user":"<USER>","app":"admin_audit","method":"POST","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v2\/push?proxyServer=https:\/\/push-notifications.nextcloud.com&devicePublicKey=-----BEGIN%20PUBLIC%20KEY--- < STUFF > ---END%20PUBLIC%20KEY-----%0A&pushTokenHash= < TOKEN > &format=json","message":"Login successful: \"<USER>\"","userAgent":"Mozilla\/5.0 (Android) Nextcloud-Talk v2.0.2","version":"13.0.4.0"}
{"reqId":"Hiz9sM16iBAUCy6nKem7","level":1,"time":"2018-06-27T04:07:20+00:00","remoteAddr":"xxx.yyy.zzz.ttt","user":"--","app":"admin_audit","method":"GET","url":"\/ocs\/v2.php\/cloud\/capabilities","message":"Login attempt: \"<USER>\"","userAgent":"Mozilla\/5.0 (Android) Nextcloud-Talk v2.0.2","version":"13.0.4.0"}
{"reqId":"Hiz9sM16iBAUCy6nKem7","level":1,"time":"2018-06-27T04:07:20+00:00","remoteAddr":"xxx.yyy.zzz.ttt","user":"<USER>","app":"admin_audit","method":"GET","url":"\/ocs\/v2.php\/cloud\/capabilities","message":"Login successful: \"<USER>\"","userAgent":"Mozilla\/5.0 (Android) Nextcloud-Talk v2.0.2","version":"13.0.4.0"}
{"reqId":"KkJrOrNcgwLtvWyKNY6n","level":1,"time":"2018-06-27T04:07:21+00:00","remoteAddr":"xxx.yyy.zzz.ttt","user":"--","app":"admin_audit","method":"GET","url":"\/ocs\/v2.php\/apps\/spreed\/api\/v1\/room","message":"Login attempt: \"<USER>\"","userAgent":"Mozilla\/5.0 (Android) Nextcloud-Talk v2.0.2","version":"13.0.4.0"}
{"reqId":"KkJrOrNcgwLtvWyKNY6n","level":1,"time":"2018-06-27T04:07:21+00:00","remoteAddr":"xxx.yyy.zzz.ttt","user":"<USER>","app":"admin_audit","method":"GET","url":"\/ocs\/v2.php\/apps\/spreed\/api\/v1\/room","message":"Login successful: \"<USER>\"","userAgent":"Mozilla\/5.0 (Android) Nextcloud-Talk v2.0.2","version":"13.0.4.0"}
'instanceid' => 'XXXXXX',
'passwordsalt' => 'YYYYYY',
'secret' => 'ZZZZZ',
...etc...
'datadirectory' => '<DIR>',
'overwrite.cli.url' => '<SOMETHING>',
'dbtype' => 'sqlite3',
'version' => '13.0.4.0',
'logtimezone' => 'UTC',
'mail_smtpmode' => 'smtp',
'mail_from_address' => '<HOST>',
'mail_domain' => '<DOMAIN>',
'mail_smtphost' => '<IP-ADDR>',
'theme' => '',
'loglevel' => 1,
'trashbin_retention_obligation' => 'auto',
'updatechecker' => false,
'redis' =>
'host' => 'localhost',
'port' => 6379,
'ldapIgnoreNamingRules' => false,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
<IP ADDR> - uuuuu [27/Jun/2018:14:07:20 +1000] "POST /ocs/v2.php/apps/notifications/api/v2/push?proxyServer=https://push-notifications.nextcloud.com&devicePublicKey=-----BEGIN%20PUBLIC%20KEY-----<STUFF>-----END%20PUBLIC%20KEY-----%0A&pushTokenHash=<LOTS OF HEX>&format=json HTTP/1.1" 400 112
