Hi everyone
Nextcloud version (eg, 20.0.5): 19.0.3
Operating system and version (eg, Ubuntu 20.04): Debian 9.13
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.10.3
PHP version (eg, 7.4): 7.3
My Nextcloud is running on a proxmox VM, on a local server at home.
The folders I added (via FTP) to an external local storage are available through web interface. However, when I try to navigate to a folder with a name including spaces and accent (such as “2020 Héraklion”), I run into a Propfind 404 error, and get redirected to home page.
Is this the first time you’ve seen this error? : Yes
- Add an external storage of type “local”, linking to an existing directory on the server (such as
/home/nextcloud/localshare
) - Send files to this folder via FTP, with a file name including spaces and accent letters
- In your browser, navigate to the external folder : you can see files and folder of the 1st level
- Click to access a folder with special name inside the local storage : you get a 404 error.
{"reqId":"Qk6QD7THMMqSI0fR2e2i","level":0,"time":"2021-02-15T13:28:48+00:00","remoteAddr":"109.8.222.182","user":"jaxom","app":"webdav","method":"PROPFIND","url":"/remote.php/dav/files/jaxom/Multimedia/Picture/2014/Coloc%20Chamb%C3%A9%202","message":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /Multimedia/Picture/2014/Coloc Chambé 2 could not be located","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":80,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["Coloc Chambé 2"]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":976,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->","args":["files/jaxom/Multimedia/Picture/2014/Coloc Chambé 2"]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1678,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->","args":["files/jaxom/Multimedia/Picture/2014/Coloc Chambé 2",["{DAV:}getlastmodified","{DAV:}getetag","{DAV:}getcontenttype","{DAV:}resourcetype","{http://owncloud.org/ns}fileid","{http://owncloud.org/ns}permissions","{http://owncloud.org/ns}size","{DAV:}getcontentlength","{http://nextcloud.org/ns}has-preview","{http://nextcloud.org/ns}mount-type","{http://nextcloud.org/ns}is-encrypted","{http://open-collaboration-services.org/ns}share-permissions","{http://owncloud.org/ns}tags","{http://owncloud.org/ns}favorite","{http://owncloud.org/ns}comments-unread","{http://owncloud.org/ns}owner-id","{http://owncloud.org/ns}owner-display-name","{http://owncloud.org/ns}share-types"],1]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1661,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"elementMap":[],"contextUri":"/remote.php/dav/","namespaceMap":{"DAV:":"d","http://sabredav.org/ns":"s","http://owncloud.org/ns":"oc","http://nextcloud.org/ns":"nc"},"classMap":[],"__class__":"Sabre\\Xml\\Writer"},{"__class__":"Generator"},false]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":363,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Generator"},false]},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":474,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":319,"function":"start","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":320,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/nextcloud/remote.php","line":167,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","Line":232,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:85.0) Gecko/20100101 Firefox/85.0","version":"19.0.3.1","id":"602a7a024b1f5"}
{"reqId":"tIa1sfPEWuBSZPbvU8OH","level":0,"time":"2021-02-15T13:56:05+00:00","remoteAddr":"109.8.222.182","user":"jaxom","app":"webdav","method":"PROPFIND","url":"/remote.php/dav/files/jaxom/Multimedia/Picture/2014/Fin%20d'%C3%A9t%C3%A9%202015","message":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /Multimedia/Picture/2014/Fin d'été 2015 could not be located","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":80,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["Fin d'été 2015"]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":976,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->","args":["files/jaxom/Multimedia/Picture/2014/Fin d'été 2015"]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1678,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->","args":["files/jaxom/Multimedia/Picture/2014/Fin d'été 2015",["{DAV:}getlastmodified","{DAV:}getetag","{DAV:}getcontenttype","{DAV:}resourcetype","{http://owncloud.org/ns}fileid","{http://owncloud.org/ns}permissions","{http://owncloud.org/ns}size","{DAV:}getcontentlength","{http://nextcloud.org/ns}has-preview","{http://nextcloud.org/ns}mount-type","{http://nextcloud.org/ns}is-encrypted","{http://open-collaboration-services.org/ns}share-permissions","{http://owncloud.org/ns}tags","{http://owncloud.org/ns}favorite","{http://owncloud.org/ns}comments-unread","{http://owncloud.org/ns}owner-id","{http://owncloud.org/ns}owner-display-name","{http://owncloud.org/ns}share-types"],1]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1661,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"elementMap":[],"contextUri":"/remote.php/dav/","namespaceMap":{"DAV:":"d","http://sabredav.org/ns":"s","http://owncloud.org/ns":"oc","http://nextcloud.org/ns":"nc"},"classMap":[],"__class__":"Sabre\\Xml\\Writer"},{"__class__":"Generator"},false]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":363,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Generator"},false]},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":474,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":319,"function":"start","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":320,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/nextcloud/remote.php","line":167,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","Line":232,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:85.0) Gecko/20100101 Firefox/85.0","version":"19.0.3.1","id":"602a7e74bc714"}
The folders are then hidden from the web interface, but they are still in my file system, and get redisplayed after the cronjob runs. It seems to be a trouble of how the filesystem manages the special characters ?
Any tip would be of help, thanks a lot !!
