Hi, I have installes Nextcloudpi the very first time and it worked out. I can access nextcloud via abc.ddns.net (safe connection). But if I want to switch to the Web Panel, the page cannot be found (abc.ddns.net:4443). I can log on with local IP (192...*2:4443) but it says that website is not save (no certificate).
I tried to add my ddns address to the trusted domains in the Web Panel but that also fails with: “System config value trusted_domains => 20 set to string”.
Port 443 is set in the router.
Any tips.
Thanks
TuG
