I have some problems with nextcloud upgrades.
My NC is installed on a shared webspace.
Trying to upgrade with the web GUI im running into the PHP timeout. SSH makes problems as well.
Would this idea work:
Before upgrading with the web GUI I would try to dissable all apps, not deinstall but disable.
Because during the upgrade also this apps will be updated which takes a lot of time and couses the timeout.
After the update is finished I would reactive the apps step by step.
Will this work without any losses in the apss configuration?
Any experiences?
Thanks
Stefan
