Nextcloud version: 18.0.2
Operating system and version: Debian 10.3
Apache or nginx version: Apache 2.4.38
PHP version: 7.3.15
If I open any Text-File in the interface, that is not a Markdown-File, the Editor loads infinitely. A look into the Network-Traffic shows that the content of the file is sent to the Frontend.
*.txt
-Files sometimes work but Files like *.java
or *.yaml
won’t.
Is this the first time you’ve seen this error?: Yes
- Upload any non Markdown-File
- Open the Network-Tab of the Developer tools in your Browser
- Try to open the file within the Web-Interface
- Wait
The output of your Nextcloud log in Admin > Logging: Nothing
'instanceid' => '[REMOVED]',
'passwordsalt' => '[REMOVED]',
'secret' => '[REMOVED]',
0 => 'cloud.domain.tld',
'datadirectory' => '/var/www/domain/cloud/data',
'overwrite.cli.url' => 'https://cloud.domain.tld',
'version' => '18.0.2.2',
'dbname' => '[REMOVED]',
'dbhost' => '[REMOVED]',
'dbtableprefix' => '[REMOVED]',
'dbuser' => '[REMOVED]',
'dbpassword' => '[REMOVED]',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'domain.tld',
'mail_smtpauth' => 1,
'mail_smtphost' => '[REMOVED]',
'mail_smtpport' => '[REMOVED]',
'mail_smtpname' => '[REMOVED]',
'mail_smtppassword' => '[REMOVED]',
'theme' => '',
'loglevel' => 2,
'mail_smtpsecure' => 'ssl',
'default_language' => 'de',
'default_locale' => 'de',
'allow_user_to_change_display_name' => false,
The output of your Apache/nginx/system log in /var/log/access.log
(error.log is empty):
93.213.237.236 - - [17/Mar/2020:12:49:14 +0100] "PROPFIND /remote.php/dav/files/[REMOVED]/[REMOVED].java HTTP/1.1" 207 2764 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0"
93.213.237.236 - - [17/Mar/2020:12:49:15 +0100] "GET /apps/text/session/create?fileId=8159&filePath=[REMOVED].java&guestName=null&forceRecreate=false HTTP/1.1" 200 1488 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0"
93.213.237.236 - - [17/Mar/2020:12:49:15 +0100] "GET /apps/text/session/fetch?documentId=8159&sessionId=74&sessionToken=[REMOVED] HTTP/1.1" 200 1709 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0"
