Hi there,
yesterday i updated my masterbranch, sadly, for a short moment, i forget that master means develop on nextcloud.
So i landet on nextcloud 11a, which is at least a compatibility problem for many apps.
Well, as i switched to the git repo as an alternative for the broken updater, i also forgot the tags for a short moment, so the clouds version number is 9.2.0.2
. But i wich to switch to the current release candidate and don’t wanna stay on develop. The last update was …maybe… two weeks ago?
And the release candidate is on 9.1.0.15
I only have usuable database backup for mentioned 9.2.0.2 snapshot (the the older one is maybe too old, not sure), i guess i updated on the day where the security fix came out (.53) and i don’t saved the nextcloud folder. I just did a git pull
after backing up the database.
Maybe someone has an idea about my my options, would be awesome.
kind Regards
