I have two problems with the SEARCH method via WebDAV. I can search for mime types âtext/%â like in the example (https://docs.nextcloud.com/server/15/developer_manual/client_apis/WebDAV/search.html), but not for e.g. âtext/xmlâ or âimage/pngâ. Furthermore it seems that the <d:depth> tag is ignored (https://tools.ietf.org/html/rfc5323#page-22).
Example where âd:depthâ is ignored:
dirk@schleppi:~/develop/fritz/test> curl -s -u dirk:jeheim -k --noproxy '*' -H "content-Type: text/xml" -X SEARCH --data '@requests/search-test.xml' 'https://balu/nextcloud/remote.php/dav/' | xmllint --format - | head -25
<?xml version="1.0"?>
<d:multistatus xmlns:d="DAV:" xmlns:s="http://sabredav.org/ns" xmlns:oc="http://owncloud.org/ns" xmlns:nc="http://nextcloud.org/ns">
<d:response>
<d:href>/nextcloud/remote.php/dav/files/dirk/Photos/14-06-08%2020-16-22%201652.jpg</d:href>
<d:propstat>
<d:prop>
<oc:fileid>735</oc:fileid>
<d:getcontenttype>image/jpeg</d:getcontenttype>
<d:getetag>"8b6b79a4a8a257b85396e0b1c009aed7"</d:getetag>
<oc:size>2784601</oc:size>
</d:prop>
<d:status>HTTP/1.1 200 OK</d:status>
</d:propstat>
<d:propstat>
<d:prop>
<d:displayname/>
</d:prop>
<d:status>HTTP/1.1 404 Not Found</d:status>
</d:propstat>
</d:response>
<d:response>
<d:href>/nextcloud/remote.php/dav/files/dirk/SofortUpload/Camera/IMG_20180707_173251.jpg</d:href>
<d:propstat>
<d:prop>
<oc:fileid>49220</oc:fileid>
you can see that files are also listed in subdirectories. There is no difference between depth=0, 1 or infinityâŠ
Here is the corresponding XML request with d:depth = 0 and image/%:
<?xml version="1.0" encoding="UTF-8"?>
<!-- Achtung: beispiel von nextclod-developer ist falsch. url muss sein .../remote.php/dav/
relativen pfad dann nach d:scope unten...
Header: Content-Type muss text/xml oder application/xml sein. Sonst keine
SEARCH-methode vorhanden -->
<d:searchrequest xmlns:d="DAV:" xmlns:oc="http://owncloud.org/ns">
<d:basicsearch>
<d:select>
<d:prop>
<oc:fileid/>
<d:displayname/>
<d:getcontenttype/>
<d:getetag/>
<oc:size/>
</d:prop>
</d:select>
<d:from>
<d:scope>
<d:href>/files/dirk/</d:href>
<!-- <d:depth>infinity</d:depth> -->
<d:depth>0</d:depth>
</d:scope>
</d:from>
<d:where>
<d:like>
<d:prop>
<d:getcontenttype/>
</d:prop>
<!-- <d:literal>text/%</d:literal> -->
<d:literal>image/%</d:literal>
</d:like>
</d:where>
<d:orderby/>
</d:basicsearch>
</d:searchrequest>
If I change image/% to image/png in the above request I get the following error:
dirk@schleppi:~/develop/fritz/test> curl -s -u dirk:jeheim -k --noproxy '*' -H "content-Type: text/xml" -X SEARCH --data '@requests/search-test.xml' 'https://balu/nextcloud/remote.php/dav/' | xmllint --format - | head -10
<?xml version="1.0" encoding="utf-8"?>
<d:error xmlns:d="DAV:" xmlns:s="http://sabredav.org/ns">
<s:exception>Doctrine\DBAL\Exception\DriverException</s:exception>
<s:message>An exception occurred while executing 'SELECT `fileid`, `storage`, `path`, `parent`, `name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `permissions`, `checksum` FROM `oc_filecache` `file` WHERE (`storage` = ?) AND (`mimetype` COLLATE utf8mb4_general_ci LIKE ?)' with params [2, "image\/png"]:
SQLSTATE[42000]: Syntax error or access violation: 1253 COLLATION 'utf8mb4_general_ci' is not valid for CHARACTER SET 'latin1'</s:message>
</d:error>
And if I use âimage/png%â completely senseless I get this pretty error: âUnsupported query value for mimetype: image/png%, only values in the format âmime/typeâ or âmime/%â are supportedâ.
<s:exception>InvalidArgumentException</s:exception>
<s:message>Unsupported query value for mimetype: image/png%, only values in the format "mime/type" or "mime/%" are supported</s:message>
</d:error>
I am using openSuse 15.0 with nextcloud 15.0.0-lp150.56.1 from this extra-repo âhttp://ftp.gwdg.de/pub/opensuse/repositories/server:/php:/applications/openSUSE_Leap_15.0/â and MariaDB.
any ideas?
cu
