example
longer
example
here
Nextcloud version (eg, 29.0.5): v.1.54.3
Operating system and version (eg, Ubuntu 24.04): Debian 11 (bullseye)
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 8.3): replace me
I just realized ncp-snapshots are not being created. My ncp-snapshots folder is empty. I get an error reported when the cron script is run (see the logs at the end of the message) saying that my ncp-snapshots is not in a btrfs filesystem. I am quite sure my /media/myCloudDrive is a btrfs filesystem, so I am not sure what is going on.
- Activate nc-snapshots
- Check messages under
/var/mail/root
- You’ll see error message:
ERROR: not a btrfs filesystem: /media/myCloudDrive/../ncp-snapshots run-parts: /etc/cron.hourly/btrfs-snp exited with return code 1
I don’t think this is relevant because it is not a problem of Nextcloud itself but of the snapshots NCP does.
Errors in /var/mail/root:
/etc/cron.hourly/btrfs-snp:
Cannot load Zend OPcache - it was already loaded
