I have installed memcached on my vserver according to this instructions.
After the installation I’ve added this lines in my config.php:
‘memcache.local’ => ‘\OC\Memcache\Memcached’,
‘memcache.distributed’ => ‘\OC\Memcache\Memcached’,
‘memcached_servers’ => array(
array(‘localhost’, 11211),
I have no security warning in the admin area. But I’ve got a PHP error:
PHP Startup: Unable to load dynamic library ‘/opt/plesk/php/7.1/lib/php/modules/memcache.so’ - /opt/plesk/php/7.1/lib/php/modules/memcache.so: cannot open shared object file: No such file or directory at Unknown#0
The system is looking for a memcache.so file but I have installed memcached. That means I have a memcached.so file. Is this a Nextcloud issue or something on my vserver?
Nextcloud version: 12.0.2
Operating system and version: 16.04.3 LTS
Panel: Plesk Onyx 17.5.3
PHP version: 7.1.9
I just recently went through this on my install. Its a php issue on the server. Only difference is mine is in a bsd jail on a freenas server. To get memcache.local, you need APCu. ‘memcache.local’ => ‘\OC\Memcache\APCu’
I installed from bsd ports. pecl-APCu
Here is a page in the nextcloud admin guide which explains a lot of this.
‘memcached.so’ isn’t the same thing as ‘memcache.so’ and both are different than APCu (from what I read in the nextcloud documentation anyway)
According to the documentation that I linked in an earlier post APCu is required for memcache.local (I could be mistaken though, but that is how I understood it when I read through it)
I have found the mistake. In the folder /opt/plesk/php/7.1/etc/php.d/ was a memcache.ini file and this was wrong. I deleted the file and added memcached modul again:
ls -la /opt/plesk/php/7.1/lib/php/modules/
echo “extension=memcached.so” >/opt/plesk/php/7.1/etc/php.d/memcached.ini
/usr/local/psa/bin/php_handler --reread
service plesk-php71-fpm restart
had a look at this place i found that memcached.so has wrong file-rights.
in nextcloud config only add localhost, not the domain, then its working for me
14.0.3 finished!
