[/details]
Nextcloud version (eg, 18.0.2):
Operating system and version (eg, NextcloudPi 1.24.3):
Apache or nginx version (eg, Apache 2.4.38)(Raspbian):
PHP version _ Version: 7.3.14
Arbeitspeicher-Grenzwert: 2,9 GB
Maximale Ausführungszeit: 3600
Maximale Größe zum Hochladen: 100 GB
Is this the first time you’ve seen this error? (Y/N): Yes
- A File bigger than 4 GB can not be uploaded.
PASTE HERE
PASTE HERE
[webdav] Fatal: Sabre\DAV\Exception: Error while copying file to target location (copied bytes: 0, expected filesize: -1 ) at <<closure>>
0. /var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php line 156
OCA\DAV\Connector\Sabre\File->put(null)
1. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php line 316
OCA\DAV\Connector\Sabre\Directory->createFile("The Borrowers A ... v", null)
2. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php line 130
Sabre\DAV\Tree->copyNode(OCA\DAV\Upload\FutureFile {}, OCA\DAV\Connector\Sabre\Directory {}, "The Borrowers A ... v")
3. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php line 161
Sabre\DAV\Tree->copy("uploads/ncp/web ... e", "files/n***/*** ... v")
4. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 642
Sabre\DAV\Tree->move("uploads/ncp/web ... e", "files/***/***... v")
5. <<closure>>
Sabre\DAV\CorePlugin->httpMove(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
6. /var/www/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php line 105
call_user_func_array([Sabre\DAV\CorePlugin {},"httpMove"], [Sabre\HTTP\Requ ... }])
7. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 479
Sabre\Event\EventEmitter->emit("method:MOVE", [Sabre\HTTP\Requ ... }])
8. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 254
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
9. /var/www/nextcloud/apps/dav/lib/Server.php line 319
Sabre\DAV\Server->exec()
10. /var/www/nextcloud/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
11. /var/www/nextcloud/remote.php line 165
require_once("/var/www/nextcl ... p")
MOVE /remote.php/dav/uploads/ncp/web-file-upload-65641dbeceba012ebf7a13aa935e5094-1587717677860/.file
from 192.168.178.72 by ncp at 2020-04-24T08:49:39+00:00
2.
[no app in context] Error: Sabre\DAV\Exception: Error while copying file to target location (copied bytes: 0, expected filesize: -1 ) at <<closure>>
Sabre\DAV\Tree->copy("uploads/ncp/web ... e", "files/ncp/Anime ... v")
Sabre\DAV\Tree->move("uploads/ncp/web ... e", "files/ncp/Anime ... v")
5. <<closure>>
from 192.168.178.72 by ncp at 2020-04-24T08:49:38+00:00
I have change the php.ini to larger files, but it didn't help. What can I additonal do? It seems all Data bigger than 4 GB can not be copied via Drag and Drop.
Help in German or English :)
Thanks for the Help :)
