Nextcloud Version 11.0.2
Operating system and Version Debian 8.7
Apache or nginx Version Nginx:
PHP Version 7.0
my external storage in nextcloud wont work fine, i can move files to the external storage, but moving out or delete files didn´t work… and when i try to sync my folders with the client i become a error with: operation canceld or connection closed.
also changing from cron to webcron is not working.
https://cloud.sunnyteater.de/s/y5fezrAyiROWXbX
https://cloud.sunnyteater.de/s/9PBHGQSO73mhpcn
Nginx Configuration = Default, with the personal changes like root path and Domain etc.
When u Need more informations, please tell me.
Hope somebody can help me…
EDIT:
Okay, i know that must be a problem with the encryption tool.
