Hi all,
i have a problem wich drives me nuts.
I want to have my data dir on a btrfs file system.
It’s mounted on /mnt/btrfs
I made a dir “/mnt/btrfs/nextcloud”, chowned it to www-data:www-data (same as my html-dir NC rns in) with 755 rights.
I still got the message, that nextcloud can not create or write to this folder during installation / configuration.
Any hints?
Thanks
Juergen
Is your /mnt/btrfs accessible too?
What OS and version are you running?
What is the output of these commands?
$ mount |grep btrfs
$ ls -ld /mnt/btrfs
$ ls -ld /mnt/btrfs/nextcloud
$ touch /mnt/btrfs/nextcloud/testfile
$ ls -l /mnt/btrfs/nextcloud/
$ getsebool
@anon9582441
The folder /mnt/btrfs is owned by root:root and has 755 rights.
Changed it to 777. No effect.
@Steve
I’m running debian 9 an a HP microserver.
root@gen8:~# uname -a
Linux gen8 4.9.0-8-amd64 #1 SMP Debian 4.9.110-3+deb9u5 (2018-09-30) x86_64 GNU/Linux
Nginx worker process runs as www-data
root@gen8:~# ps axuf | grep nginx
root 40321 0.0 0.0 12780 1020 pts/0 S+ 10:21 0:00 | \_ grep nginx
root 19733 0.0 0.0 90228 1136 ? Ss Okt25 0:00 nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf
www-data 19734 0.0 0.0 91340 6760 ? S Okt25 0:00 \_ nginx: worker process
root@gen8:/mnt/btrfs# mount |grep btrfs
/dev/sda on /mnt/btrfs type btrfs (rw,relatime,space_cache,subvolid=5,subvol=/)
root@gen8:/mnt/btrfs# ls -ld /mnt/btrfs
drwxrwxrwx 1 root root 52 Okt 25 21:09 /mnt/btrfs
root@gen8:/mnt/btrfs# ls -ld /mnt/btrfs/nextcloud
drwxr-xr-x 1 www-data www-data 8 Okt 25 21:27 /mnt/btrfs/nextcloud
root@gen8:/mnt/btrfs# touch /mnt/btrfs/nextcloud/testfile
root@gen8:/mnt/btrfs# ls -l /mnt/btrfs/nextcloud/
insgesamt 0
-rw-r--r-- 1 root root 0 Okt 26 10:16 testfile
root@gen8:/mnt/btrfs# getsebool
getsebool: SELinux is disabled
Best regards
Juergen
ok, no more answers till now.
But as i can see more users in the forum having trouble when the data folder is not in the default location (/var/www/nextcloud/data) i would assume that there is a kind of bug here.
I will try to investigate
Juergen
you certain the reason is the FS? can you try w/ another (eg ext4)?
keeping the datadir outside the webdir is definitely possible (and sensible) - maybe there is an installation-error of some kind (eg destdir exists and cannot be created)?
on my installation i keep the data in'datadirectory' => '/home/nc/data'
(but i can’t remember if i started out with that or if i moved it later).
/home/nc/ is 755-owned by root, and inside that /data ist 750-owned by www-data:www-data.
(as an aside: if you decide to stick with btrfs it might make sense to use a more fine-grained structure of subvolumes inside the rootvol)
GOOD LUCK!
did you find a fix i am using the external storage as a workaround?
Instead of changing the data directory I simply mounted some btrfs subvolumes
directly in the www directory.
/var/www/domains/my.domain/htdocs/nextcloud/data
/var/www/domains/my.domain/htdocs/nextcloud/data/__groupfolders/1
/var/www/domains/my.domain/htdocs/nextcloud/data/__groupfolders/2
/var/www/domains/my.domain/htdocs/nextcloud/data/appdata_xxxxxxx/preview (avoids backing up previews..)
It is very easy to make snapshots and keep backups with btrbk
backup tool.
