Client no longer works with NC 24
example
I don't see anything in the logs that would indicate a problem that would affect client.
Nextcloud version (eg, 20.0.5): 24.0.2.01
Operating system and version (eg, Ubuntu 20.04): macOS
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.54
PHP version (eg, 7.4): 8.0.20
Cannot connect client to server. I can access NC from web page with no problem.
Is this the first time you’ve seen this error? Y_:
- Install several versions of client
- No version works.
Log info displays briefly and the page goes blank.
'instanceid' => '*********',
'passwordsalt' => '**************************',
'secret' => '********************',
0 => 'nc.y4x.biz',
1 => 'cl.y4x.biz',
'redis' =>
'host' => '127.0.0.1',
'port' => 6379,
'timeout' => 0,
'password' => '****************',
'dbindex' => 0,
'datadirectory' => '/var/nc_data',
'version' => '24.0.2.1',
'overwrite.cli.url' => '*********',
'overwritehost' => '*******',
'dbname' => *****',
'dbhost' => 'localhost',
'dbuser' => **********',
'dbpassword' => '********',
'tempdirectory' => '**********',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_sendmailmode' => 'pipe',
'mail_from_address' => '***',
'mail_domain' => '*********',
'mail_smtpauth' => 1,
'mail_smtphost' => '*******',
'mail_smtpport' => '587',
'mail_smtpname' => ***********',
'mail_smtppassword' => '********************',
'trashbin_retention_obligation' => 'auto,30',
'versions_retention_obligation' => 'auto,2',
'log_type' => 'file',
'loglevel' => 0,
'logfilemode' => 420,
'debug' => true,
'log_rotate_size' => 10485760,
'logtimezone' => 'America/Boise',
'activity_expire_days' => 4,
'theme' => '',
'default_phone_region' => 'US',
'default_locale' => 'en_US',
'defaultapp' => 'files',
'app_install_overwrite' =>
0 => 'spreedme',
1 => 'nextbackup',
2 => 'cookbook',
3 => 'epubreader',
'updater.secret' => '********************',
PASTE HERE
PASTE HERE
None
