Problems with AiO docker and traefik
I am running into the problem that I do not get the apache container to listen on ipv4 it seem.
My docker-compose.yml
version: '3.2'
services:
    restart: always
    init: true
    networks:
      - net
      - nextcloud-aio
    ports:
      - 50082:8080
    volumes:
      - /volume1/docker/nextcloud/nextcloud_aio/html:/var/www/html
    environment:
      - APACHE_PORT=11000
      - APACHE_IP_BINDING=0.0.0.0
      - APACHE_ADDITIONAL_NETWORK=net
      - NEXTCLOUD_DATADIR=/volume1/Nextcloud/data
      - NEXTCLOUD_UPLOAD_LIMIT=10G
      - NEXTCLOUD_MEMORY_LIMIT=4096M
      - NEXTCLOUD_ENABLE_DRI_DEVICE=true
      - SKIP_DOMAIN_VALIDATION=true
    labels:
      - "traefik.enable=true"
      # Define Router for Nextcloud
      - "traefik.http.routers.nextcloud.rule=Host(`sub.example.com`)"
      - "traefik.http.routers.nextcloud.entrypoints=websecure"
      - "traefik.http.routers.nextcloud.tls=true"
      - "traefik.http.routers.nextcloud.tls.certresolver=cloudflare"
      # HTTP to HTTPS Redirect
      - "traefik.http.routers.nextcloud-http.rule=Host(`sub.example.com`)"
      - "traefik.http.routers.nextcloud-http.entrypoints=web"
      - "traefik.http.routers.nextcloud-http.middlewares=nextcloud-https@docker"
      - "traefik.http.middlewares.nextcloud-https.redirectscheme.scheme=https"
      # Point Traefik to Nextcloud Apache
      - "traefik.http.services.nextcloud.loadbalancer.server.port=11000"
volumes:
networks:
  net:
    external: true
  nextcloud-aio:
    external: true
Notes:
  • The reason I have two networks is because my other services use net when connected to Traefik.
  • Traefik is connected to both nextcloud_aio and net
The output of docker exec -it nextcloud-aio-apache netstat -tulnp gives me
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.11:36828        0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      38/httpd
tcp        0      0 127.0.0.1:2019          0.0.0.0:*               LISTEN      -
tcp        0      0 :::11000                :::*                    LISTEN      -
udp        0      0 127.0.0.11:38596        0.0.0.0:*                           -
The output of docker exec -it nextcloud-aio-mastercontainer netstat -tulnp:
tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      152/httpd
tcp        0      0 127.0.0.11:38116        0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      152/httpd
tcp        0      0 127.0.0.1:9876          0.0.0.0:*               LISTEN      -
tcp        0      0 :::9000                 :::*                    LISTEN      157/php-fpm.conf)
tcp        0      0 :::80                   :::*                    LISTEN      -
tcp        0      0 :::8443                 :::*                    LISTEN      -
udp        0      0 127.0.0.11:60860        0.0.0.0:*                           -
Traefik log tells me the following where 172.21.0.2 is the ip for nextcloud-aio-mastercontainer.
2025-03-01T05:53:31+02:00 DBG github.com/traefik/traefik/v3/pkg/server/service/loadbalancer/wrr/wrr.go:213 > Service selected by WRR: http://172.21.0.2:11000
2025-03-01T05:53:31+02:00 DBG github.com/traefik/traefik/v3/pkg/proxy/httputil/proxy.go:115 > 502 Bad Gateway error="dial tcp 172.21.0.2:11000: connect: connection refused"
172.18.0.1 - - [01/Mar/2025:03:53:31 +0000] "GET /index.php/204 HTTP/2.0" 502 11 "-" "-" 2219 "nextcloud@docker" "http://172.21.0.2:11000" 1ms
I’d really appreciate some help as I’m either too caffeinated by now, or just did something very stupid.
Cheers
Hi, can you check
