Problems with a db error Doctrine\DBAL\Exception
example
longer
example
here
Nextcloud version (eg, 20.0.5): 28.0.5.1
Operating system and version (eg, Ubuntu 20.04): Debian 12
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.59
PHP version (eg, 7.4): PHP 8.3.7
Hi
I cannot backup up via nextcloudpi and my log seems to be spamming those DB errors.
I previously had the deepl, the right-click menu and the splash apps, which seemed to be untested, but I since removed them. No idea if that’s related tough.
  1. To be honest, not really sure.
  2. Could possibly be related to the installed apps above
What I also did is, I had a problem with the imagick module, have now read the posts about security.
I execute the following commands, but reverted all of them:
apt install php-imagick
apt-get install php8.1-imagick
apt-get install php8.3-imagick # -> Was already installed as expected
Reverted them:
apt remove php-imagick
apt remove php8.1-imagick
apt clean && apt autoclean && apt autoremove
Rebooted the server and my problems below with the DB are still persistent
Error	cron
Exception
Failed to connect to the database: An exception occurred in the driver: could not find driver
Exception thrown: Doctrine\DBAL\Exception
May 29, 2024, 10:10:01 PM
Error	cron
Exception
May 29, 2024, 10:05:01 PM
Error	cron
Exception
May 29, 2024, 10:00:01 PM
Error	cron
Exception
May 29, 2024, 9:55:01 PM
Error	cron
Exception
May 29, 2024, 9:50:01 PM
Error	cron
Exception
May 29, 2024, 9:45:01 P
  'passwordsalt' => '{mysalt}',
  'secret' => '{mysecret}',
    0 => 'localhost',
    7 => 'nextcloudpi',
    5 => 'nextcloudpi.local',
    8 => 'nextcloudpi.lan',
    3 => 'nextcloudpi',
    11 => '{pubip}',
    1 => '10.10.20.14',
    14 => 'nextcloud.home',
    20 => '{sub2.domain.tld}',
    21 => '{sub.domain.tld}',
  'datadirectory' => '/opt/ncdata/data',
  'version' => '28.0.5.1',
  'overwrite.cli.url' => 'https://nextcloudpi/',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost',
  'dbuser' => '{mydbuser_obfuscated}',
  'dbpassword' => '{mydbpassword_obfuscated}',
  'instanceid' => 'oc55fg5jcnox',
  'redis' =>
    'host' => '/var/run/redis/redis.sock',
    'port' => 0,
    'timeout' => 0.0,
    'password' => '{mypw_obfuscated}',
  'tempdirectory' => '/opt/ncdata/data/tmp',
  'mail_smtpmode' => 'sendmail',
  'mail_from_address' => 'noreply',
  'mail_domain' => 'nextcloudpi.com',
  'preview_max_x' => '2048',
  'preview_max_y' => '2048',
  'jpeg_quality' => '60',
  'logfile' => '/opt/ncdata/data/nextcloud.log',
  'trusted_proxies' =>
    11 => '127.0.0.1',
    12 => '::1',
    0 => '10.10.20.13',
    1 => '10.10.20.13',
  'loglevel' => '2',
  'log_type' => 'file',
  'app_install_overwrite' =>
    0 => 'unsplash',
    1 => 'transmission',
    2 => 'files_markdown',
    3 => 'files_rightclick',
  'maintenance_window_start' => 3,
  'default_phone_region' => 'CH',
[Wed May 29 22:14:15.224145 2024] [authz_host:error] [pid 249:tid 129263044921024] [remote 192.168.1.200:52223] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Wed May 29 22:14:15.228379 2024] [authz_host:error] [pid 249:tid 129262908606144] [remote 192.168.1.200:52223] AH01753: access check of 'localhost' to /img/download.svg failed, reason: unable to get the remote host name
[Wed May 29 22:14:15.231743 2024] [authz_host:error] [pid 249:tid 129263023949504] [remote 192.168.1.200:52223] AH01753: access check of 'localhost' to /img/delete.svg failed, reason: unable to get the remote host name
[Wed May 29 22:14:15.330052 2024] [authz_host:error] [pid 249:tid 129263034435264] [remote 192.168.1.200:52223] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Wed May 29 22:14:15.375483 2024] [authz_host:error] [pid 249:tid 129263034435264] [remote 192.168.1.200:52223] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Wed May 29 22:14:33.386634 2024] [authz_host:error] [pid 249:tid 129262971520704] [remote 192.168.1.200:52223] AH01753: access check of 'localhost' to /img/red-circle.svg failed, reason: unable to get the remote host name, referer: https://10.10.20.14:4443/css/ncp.css
[Wed May 29 22:14:33.429443 2024] [authz_host:error] [pid 249:tid 129262971520704] [remote 192.168.1.200:52223] AH01753: access check of 'localhost' to /img/red-circle.svg failed, reason: unable to get the remote host name, referer: https://10.10.20.14:4443/css/ncp.css```
[PASTE HERE](https://pastebin.com/TXQvPx6X)
Huge thanks for any help, really appreciate it!
Hey! Thanks for your post! Just to check – does this problem still persist after a restart of the raspberry pi?
Thanks for the reply,
It’s a debian LXC hosted on Proxmox.
As far as I can remember it persisted after a reboot.
But I could fix it via the following commands:
apt-get install -y php8.3-pgsql php8.3-zip php8.3-dom php8.3-xml php8.3-xmlreader php8.3-xmlwriter php8.3-mbstring php8.3-gd php8.3-simplexml php8.3-curl
Sepcifically the package php8.3-pgsql uninstalling and reinstalling fixed the db error, then I got an error telling me that other packages are missing, which could be fixed by installing the others. No idea how this happened, because I installed this instance just like 6 days ago
