Dear all,
registration and directly an ask for help
I’m from Germany, and have not much aka non knowledge about Linux, Dockers aso. So, perfect for installing Nextcould on openmediavault via portainer on a Lenovo m70q… (Not for Backup, currently only in LAN)
As far, everything worked out well and I made it to the point that I have access to NC Hub 4.0 and already synced data, yeah.
I have 2 SSD in my m70q:
2 TB NVME for OMV (dev/nvme0n1p1-p3, 30 GB) and free rest (via gparted) mounted in OMV as storage (dev/nvme0n1p4)
4 TB SATA for storage (dev/sda1)
Both mounted in /srv/… (a problem?)
When I look no into NC-Admin settings, HDD Storage amount only shows 30 GB, probably from from OMVs drive (nvme0n1p2). And more than 30 GB is not syncable… already locked my webGUI but solved it…
I wished that the 4 TB drive would be used for NC. That’s my Problem. (Besides that Win Client is syncing slowly as… only 10% from available speed. Will be next question )
What I already did is changing the editor file from https://www.wundertech.net/how-to-install-nextcloud-on-openmediavault/ I used:
- I mkdir nextcloud with sub folders app, and database (also daten, but not in use)
- put those folders in portainer editor: - /sda1/nextcloud/database:/var/lib/mysql and - /sda1/nextcloud/app:/var/www/html
But data still not landing on the 4 TB. What did I do wrong? Shall I some how say portainer, that it should go there? Im lost, totally lost
Maybe someone has a bit time to give me a hint what to do next. That would be awesome!
Thank you, Seb
Currently running in portainer (Anything else missing?):
version: ‘2’
services:
db:
image: mariadb:10.5
restart: always
volumes:
environment:
- MYSQL_ROOT_PASSWORD=–
- MYSQL_PASSWORD=–
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
app:
image: nextcloud
restart: always
ports:
- 8080:80
links:
- db
volumes:
environment:
- MYSQL_PASSWORD=–
- MYSQL_HOST=db
