Greetings
I am using a server with cpanel and I installed Nextcloud via Web through Softaculous apps
OS Linux
Apache 2.4.43
PHP 7.2.31
MySQL Maria 10.3.23
NC ver 19.0.0
I am trying to using Onlyoffice with Document Server but I can’t access the files. Every time I open a Document it said “connection is lost” and it shows a blank file and I checked the logs and I have these problems
“You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead at mydomain/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18” every seconds these messages appear
Error occurred while checking server setup
Your web server is not properly set up to resolve “/nextcloud/ocm-provider/”. This is most likely related to a web server configuration that was not updated to deliver this folder directly.
Your web server is not properly set up to resolve “/nextcloud/ocs-provider/”
Your web server is not properly set up to resolve “/.well-known/caldav”
Your web server is not properly set up to resolve “/.well-known/carddav”
I am new to this, so sorry for the maybe dumb questions
