Hello everyone,
I’ve set up a Nextcloud server (snap version) in my LAN network. For reaching the server from the WAN, I’ve configured a DuckDNS client. In my router I’ve added forwarding port rules for 80/TCP and 443/TCP.
I’ve also used Let’s Encrypt for generating an SSL certificate and using HTTPS.
Additionally, I’ve added a DNS entry that maps my DDNS address to the static IP of the nextcloud server.
I’ve downloaded the android app of nextcloud and I can reach the nextcloud server using the DuckDNS domain. However, I don’t success in logging in with the phone when I’m inside the LAN. The server gives time out errors most of the time. I’ve achieved log in using the QR code, but still the app is unusable. The resource usage in the server is very low so I discard that it’s performance problems.
On the other hand, using the IP address goes perfect and smooth, but it’s obviously useless for outside the LAN.
Reaching the server from the WAN via DDNS works also totally fine. I must be missing something. Could you please give me ideas of what else have to be configured?
Nextcloud version : 19.0.1.1
Operating system and version : Ubuntu 18.04 LTS
Apache or nginx version : Apache (snap version)
PHP version: (snap version)
Error PHP Cannot modify header information - headers already sent by (output started at /snap/nextcloud/22400/htdocs/3rdparty/sabre/http/lib/Sapi.php:132) at /snap/nextcloud/22400/htdocs/apps/dav/lib/Connector/Sabre/File.php#680 2020-07-29T21:35:43+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 10485760 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 7290880 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-29T21:35:43+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 10485760 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 7290880 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-29T21:35:43+0200
Error PHP imagecreatefromstring(): Data is not in a recognized format at /snap/nextcloud/22400/htdocs/lib/private/legacy/OC_Image.php#624 2020-07-28T23:16:45+0200
Error PHP Cannot modify header information - headers already sent by (output started at /snap/nextcloud/22400/htdocs/3rdparty/sabre/http/lib/Sapi.php:132) at /snap/nextcloud/22400/htdocs/apps/dav/lib/Connector/Sabre/File.php#680 2020-07-28T19:44:58+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 2729488 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 1130496 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-28T19:44:58+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 2729488 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 1130496 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-28T19:44:58+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 1721072 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 147456 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-28T19:44:58+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 1721072 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 147456 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-28T19:44:58+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 4320320 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 4308992 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-28T19:44:58+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 4320320 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 4308992 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-28T19:44:58+0200
Error PHP Cannot modify header information - headers already sent by (output started at /snap/nextcloud/22400/htdocs/3rdparty/sabre/http/lib/Sapi.php:132) at /snap/nextcloud/22400/htdocs/apps/dav/lib/Connector/Sabre/File.php#680 2020-07-28T19:27:39+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 1486096 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 999424 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-28T19:27:39+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 1486096 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 999424 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-28T19:27:39+0200
Error PHP Cannot modify header information - headers already sent by (output started at /snap/nextcloud/22400/htdocs/3rdparty/sabre/http/lib/Sapi.php:132) at /snap/nextcloud/22400/htdocs/apps/dav/lib/Connector/Sabre/File.php#680 2020-07-27T23:56:58+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 30200073 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 25493504 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T23:56:58+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 29614527 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 16433152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T23:56:58+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 32081777 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 13516800 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T23:56:58+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 32081777 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 13516800 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T23:56:58+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 29614527 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 16433152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T23:56:58+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 30200073 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 25493504 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T23:56:58+0200
Error PHP Cannot modify header information - headers already sent by (output started at /snap/nextcloud/22400/htdocs/3rdparty/sabre/http/lib/Sapi.php:132) at /snap/nextcloud/22400/htdocs/apps/dav/lib/Connector/Sabre/File.php#680 2020-07-27T21:41:20+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 25932776 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 20545536 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T21:41:20+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 26931377 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 23707648 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T21:41:20+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 25932776 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 20545536 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T21:41:20+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 26931377 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 23707648 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T21:41:20+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 25824491 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 3506176 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T21:41:20+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 25824491 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 3506176 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T21:41:20+0200
Error PHP session_start(): A session had already been started - ignoring at /snap/nextcloud/22400/htdocs/lib/private/Session/Internal.php#209 2020-07-27T20:07:21+0200
Error PHP Cannot modify header information - headers already sent by (output started at /snap/nextcloud/22400/htdocs/3rdparty/sabre/http/lib/Sapi.php:132) at /snap/nextcloud/22400/htdocs/apps/dav/lib/Connector/Sabre/File.php#680 2020-07-27T19:53:19+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 2845598 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 2539520 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T19:53:19+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 2845598 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 2539520 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T19:53:19+0200
Error index Exception: Call to a member function stat() on null 2020-07-27T19:43:28+0200
Error PHP session_start(): A session had already been started - ignoring at /snap/nextcloud/22400/htdocs/lib/private/Session/Internal.php#209 2020-07-27T19:41:05+0200
Error PHP Cannot modify header information - headers already sent by (output started at /snap/nextcloud/22400/htdocs/3rdparty/sabre/http/lib/Sapi.php:132) at /snap/nextcloud/22400/htdocs/apps/dav/lib/Connector/Sabre/File.php#680 2020-07-27T19:03:36+0200
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 2675628 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 2129920 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T19:03:36+0200
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 2675628 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 2129920 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2020-07-27T19:03:36+0200
Error cron Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] No such file or directory 2020-07-27T18:45:03+0200
Error cron Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] No such file or directory 2020-07-26T23:55:43+0200
The output of config.php file in /var/snap/nextcloud/22400/nextcloud/config/
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
'url' => '/extra-apps',
'writable' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'instanceid' => 'ocxaa7xju08z',
'passwordsalt' => 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX',
'secret' => 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX',
0 => '192.168.X.XX',
1 => 'exampledns.duckdns.org',
'datadirectory' => '/var/snap/nextcloud/common/nextcloud/data',
'version' => '19.0.1.1',
'overwrite.cli.url' => 'http://192.168.X.XX',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => 'nextcloud',
'dbpassword' => 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX',
The output of apache log in /var/snap/nextcloud/22400/apache/logs/error_log
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
[Thu Jul 23 18:34:10.779785 2020] [mpm_event:notice] [pid 3922:tid 140342625562624] AH00489: Apache/2.4.43 (Unix) configured -- resuming normal operations
[Thu Jul 23 18:34:10.779937 2020] [core:notice] [pid 3922:tid 140342625562624] AH00094: Command line: 'httpd -d /snap/nextcloud/22400 -D FOREGROUND'
[Thu Jul 23 18:34:10.783655 2020] [unixd:alert] [pid 3933:tid 140342625562624] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 18:34:10.783673 2020] [unixd:alert] [pid 3932:tid 140342625562624] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 18:34:10.783680 2020] [unixd:alert] [pid 3931:tid 140342625562624] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 18:41:28.560922 2020] [mpm_event:notice] [pid 3922:tid 140342625562624] AH00491: caught SIGTERM, shutting down
[Thu Jul 23 18:42:07.125789 2020] [mpm_event:notice] [pid 2730:tid 140197433630720] AH00489: Apache/2.4.43 (Unix) configured -- resuming normal operations
[Thu Jul 23 18:42:07.125939 2020] [core:notice] [pid 2730:tid 140197433630720] AH00094: Command line: 'httpd -d /snap/nextcloud/22400 -D FOREGROUND'
[Thu Jul 23 18:42:07.133756 2020] [unixd:alert] [pid 2734:tid 140197433630720] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 18:42:07.133773 2020] [unixd:alert] [pid 2735:tid 140197433630720] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 18:42:07.133780 2020] [unixd:alert] [pid 2736:tid 140197433630720] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 18:50:55.617347 2020] [mpm_event:notice] [pid 2730:tid 140197433630720] AH00491: caught SIGTERM, shutting down
[Thu Jul 23 18:51:37.366882 2020] [mpm_event:notice] [pid 2538:tid 139771701370880] AH00489: Apache/2.4.43 (Unix) configured -- resuming normal operations
[Thu Jul 23 18:51:37.367054 2020] [core:notice] [pid 2538:tid 139771701370880] AH00094: Command line: 'httpd -d /snap/nextcloud/22400 -D FOREGROUND'
[Thu Jul 23 18:51:37.372953 2020] [unixd:alert] [pid 2544:tid 139771701370880] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 18:51:37.372938 2020] [unixd:alert] [pid 2545:tid 139771701370880] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 18:51:37.372962 2020] [unixd:alert] [pid 2541:tid 139771701370880] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 19:01:49.643324 2020] [unixd:alert] [pid 3202:tid 139771701370880] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 19:02:36.434045 2020] [mpm_event:notice] [pid 2538:tid 139771701370880] AH00491: caught SIGTERM, shutting down
[Thu Jul 23 19:03:22.959871 2020] [mpm_event:notice] [pid 2558:tid 140138140622848] AH00489: Apache/2.4.43 (Unix) configured -- resuming normal operations
[Thu Jul 23 19:03:22.960026 2020] [core:notice] [pid 2558:tid 140138140622848] AH00094: Command line: 'httpd -d /snap/nextcloud/22400 -D FOREGROUND'
[Thu Jul 23 19:03:22.971603 2020] [unixd:alert] [pid 2566:tid 140138140622848] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 19:03:22.971599 2020] [unixd:alert] [pid 2564:tid 140138140622848] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 19:03:22.971591 2020] [unixd:alert] [pid 2565:tid 140138140622848] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 19:06:17.166023 2020] [unixd:alert] [pid 11722:tid 140138140622848] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 19:32:52.737214 2020] [mpm_event:notice] [pid 2558:tid 140138140622848] AH00491: caught SIGTERM, shutting down
[Thu Jul 23 20:11:55.342190 2020] [mpm_event:notice] [pid 2715:tid 140357331333120] AH00489: Apache/2.4.43 (Unix) configured -- resuming normal operations
[Thu Jul 23 20:11:55.342342 2020] [core:notice] [pid 2715:tid 140357331333120] AH00094: Command line: 'httpd -d /snap/nextcloud/22400 -D FOREGROUND'
[Thu Jul 23 20:11:55.352233 2020] [unixd:alert] [pid 2717:tid 140357331333120] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 20:11:55.352246 2020] [unixd:alert] [pid 2719:tid 140357331333120] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 20:11:55.352255 2020] [unixd:alert] [pid 2718:tid 140357331333120] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 20:13:40.025660 2020] [unixd:alert] [pid 3718:tid 140357331333120] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 22:19:33.185726 2020] [mpm_event:notice] [pid 2715:tid 140357331333120] AH00491: caught SIGTERM, shutting down
[Thu Jul 23 22:20:26.251314 2020] [mpm_event:notice] [pid 3093:tid 140100200615936] AH00489: Apache/2.4.43 (Unix) configured -- resuming normal operations
[Thu Jul 23 22:20:26.251539 2020] [core:notice] [pid 3093:tid 140100200615936] AH00094: Command line: 'httpd -d /snap/nextcloud/22400 -D FOREGROUND'
[Thu Jul 23 22:20:26.269573 2020] [unixd:alert] [pid 3096:tid 140100200615936] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 22:20:26.269571 2020] [unixd:alert] [pid 3097:tid 140100200615936] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 22:20:26.269566 2020] [unixd:alert] [pid 3095:tid 140100200615936] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 22:20:30.257679 2020] [unixd:alert] [pid 3526:tid 140100200615936] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Thu Jul 23 22:26:37.259052 2020] [mpm_event:notice] [pid 3093:tid 140100200615936] AH00491: caught SIGTERM, shutting down
[Thu Jul 23 22:27:29.407980 2020] [mpm_event:notice] [pid 3030:tid 139872657686528] AH00489: Apache/2.4.43 (Unix) configured -- resuming normal operations
[Thu Jul 23 22:27:29.408167 2020] [core:notice] [pid 3030:tid 139872657686528] AH00094: Command line: 'httpd -d /snap/nextcloud/22400 -D FOREGROUND'
[Thu Jul 23 22:27:29.418907 2020] [unixd:alert] [pid 3036:tid 139872657686528] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
