I’m trying to upgrade from 10.0.4 to 11.0.3. But I get the following error when running occ upgrade
from the 11.x copy of NC:
Exception: Updates between multiple major versions and downgrades are unsupported. Update failed
Then going back to the 10.x copy, if I run occ upgrade
it says Nextcloud is already latest version
. If I run occ status
I get:
- installed: true
- version: 9.1.4.2
- versionstring: 10.0.4
- edition:
I wonder about the 9.x
value of version
. And what is the difference between version
and versionstring
When running the 10.x code, I also get a notification about a newer version of Owncloud 9.x is available. What is going on? It’s all mess, but 10.x has been running without problems.
