Nextcloud version (14.0.4):
Operating system and version (Raspbian GNU/Linux 9 (stretch)):
Apache/2.4.25
PHP version: PHP 7.0.33-0+deb9u1 (cli)
Trying to update via web-updater to v. 14.0.6 gives the error: “Verifying integrity
Parsing response failed. Step 5 is currently in process. Please reload this page later.”
When trying again, a white page is shown telling: “Step 5 is currently in process. Please reload this page later.”
When using updater on command line the error is: “[ ] Verify integrity …Ungültiger Maschinenbefehl” and after trying again also: “Step 5 is currently in process. Please call this command later.”
Is this the first time you’ve seen this error? (Y/N): Yes
- Update via web-updater or command line from v.14.0.4 to 14.0.6
|Warning|l10n|Failed to load /var/www/nextcloud/lib/l10n/sr.json - json error code: 4|2019-01-29T21:14:41+0100|
|Warning|l10n|Failed to load /var/www/nextcloud/lib/l10n/it.json - json error code: 4|2019-01-29T21:14:41+0100|
|Warning|l10n|Failed to load /var/www/nextcloud/lib/l10n/sr.json - json error code: 4|2019-01-29T20:30:40+0100|
|Warning|l10n|Failed to load /var/www/nextcloud/lib/l10n/it.json - json error code: 4|2019-01-29T20:30:40+0100|
'instanceid' => '*******',
'passwordsalt' => '*****************',
'secret' => '**********',
0 => '192.168.2.***',
1 => '********',
'datadirectory' => '/media/stick/nextcloud',
'overwrite.cli.url' => 'http://192.168.2.***',
'version' => '14.0.4.2',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '**********',
'dbpassword' => '******',
'mail_from_address' => '***********
'mail_smtpmode' => 'php',
'mail_domain' => 'localhost',
'logfile' => '/media/stick/nextcloud/nextcloud.log',
'loglevel' => 2,
'updater.release.channel' => 'production',
'theme' => '',
'updater.secret' => '*****************',
[Tue Jan 29 20:36:22.669041 2019] [core:notice] [pid 818] AH00052: child pid 857 exit signal Illegal instruction (4)
[Tue Jan 29 20:55:57.642970 2019] [mpm_prefork:notice] [pid 818] AH00169: caught SIGTERM, shutting down
[Tue Jan 29 20:56:35.456551 2019] [mpm_prefork:notice] [pid 818] AH00163: Apache/2.4.25 (Raspbian) OpenSSL/1.0.2q configur$
[Tue Jan 29 20:56:35.462378 2019] [core:notice] [pid 818] AH00094: Command line: '/usr/sbin/apache2'
