example
longer
example
here
Nextcloud version : 19.0.1
Operating system and version : Ubuntu 20.04
Apache or nginx version : Apache 2.4.43
PHP version : 7.4
Hardware : Raspberry Pi 4b+ (Connected on Gigabyte ethernet)
Transferring some files (like 10 files at the same time) over WebDAV (that i setted up as a map drive) takes long times because the bandwidth is going up and down (down like to zero bytes/s) every five seconds.
Sometimes i’m at 50 mb/s and five secondes later at 0 mb/s, than go back to 50 again and again.
Here’s the graph to see what i mean :
Every time the bandwidth hit 0, the transfer freeze for like 5-10sec, actually that’s the real problem.
I dont understand because in php.ini i set values like max_file_size = 16G and max_files_per_request(something like that) = 300
- Setup Nextcloud as Apache directory (i mean no docker or what), setted as nextcloud.example.org
- Setup external storage on a local directory on my mounted external drive
- On Windows, copy link of the WebDAV remote thing URL, paste it as a new map network drive
- Try to paste on the directory of WebDAV some files
Sorry did't get what you asked for
'instanceid' => 'oc7bonn9xdtx',
'passwordsalt' => '',
'secret' => '',
0 => 'nextcloud.example.org',
'datadirectory' => '/mnt/disk0/data',
'version' => '19.0.1.1',
'overwrite.cli.url' => 'https://nextcloud.example.org',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '',
'dbpassword' => '',
Sorry didn't get that either
