Problems syncing Error:5
Hello, along with say hello. Can someone help me with the network error: 5
It shows me every time it synchronizes the nextcloud that I have installed on Windows.
We will do everything for you. Wait. Oops! Something went wrong (Microsoft)
Hello, after a long search for what problem I had, I detected that it was the rclone that was causing the problem. I have Rclone activated because I have an external backup on Google Drive. I disabled rclone and the error disappeared.
I have managed to backup nextcloud to my Google Drive, the mistake I made was that I used rclone mount and the solution was rclone sync. This is because having rclone installed caused a problem on the network as it was simultaneously backing up nextcloud and at the same time google drive.
the command you use is
rclone sync path remote:DESTINATION
