I appear to have some issues with running the latest desktop client from Ubuntu. I get the following error if I try to run it from terminal:
nextcloud: error while loading shared libraries: libqt5keychain.so.0: cannot open shared object file: No such file or directory
Any suggestions, would be greatly appreciated.
Many Thanks
Please test the new prerelease AppImage:
Before you can run it, you need to give it the execute permission:
https://cdn-standard4.discourse.org/uploads/appimage/optimized/1X/a4889c5cb8711d6845b58135080787d2f370af35_1_500x500.gif
Please letβs know whether this solves the issue for you.
I had the same problems. After installing the above mentioned AppImage it seems to be working now properly.
Thank you.
Yes it worked for me too. Thanks so much for your help. It is greatly appreciated.
