example
longer
example
here
Nextcloud version (eg, 12.0.2):12.0.11
Operating system and version (eg, Ubuntu 17.04):Ubuntu 16.04.5
PHP version (eg, 7.1):
The issue you are facing: trying to locate and edit the theming file according to this link: https://docs.nextcloud.com/server/12/developer_manual/core/theming.html
The goal is to disable the iOS notification that Safari shows when going to a nextcloud site. Problem is finding the theme files. The theme app is enabled in Nextcloud, but there appears to be no /nextcloud/themes folder - so I cannot edit the defaults.php file - " You can find it in the example theme ( /themes/example/defaults.php )".
Is this the first time you’ve seen this error? (Y/N):Y
PASTE HERE
PASTE HERE
PASTE HERE
