[system info at the bottom of post]
the problem:
EVerything was fine until today.
Today I tried connecting a client on my Ubuntu 18.04.1 TLS Gnome 3.28.2 64bit
This did not work -there was a refusal of connection form the server
When I tried connecting from the browser with my domain name - sometimes i succeded sometimes not.
connecting with the pi’s ip number from my browser is successful.
Also my iOS client sometimes says error count not connect to the server
and then sometimes it does connect and sync.
ports 80 and 443 are open
upnp enabled in the router
but when I try to use nc-forward-port its says i need to do it manually
I reactiveted the noip in the nextcloudpi panel
So - I am seriously confused and I can see no actual reason why this happens.
any ideas?
this is not the first time it happens. out of the blue i get all these connection issues.
System info
NextCloudPi version | v0.58.1 |
NextCloudPi image | NextCloudPi_02-06-18 |
distribution | Raspbian GNU/Linux 9 \n \l |
automount | no |
USB devices | none |
datadir | /var/www/nextcloud/data |
data in SD | yes |
data filesystem | ext2/ext3 |
data disk usage | 6.6G/30G |
rootfs usage | 6.6G/30G |
swapfile | /var/swap |
dbdir | /var/lib/mysql |
Nextcloud check | ok |
Nextcloud version | 13.0.0.14 |
HTTPD service | up |
PHP service | up |
MariaDB service | up |
Redis service | up |
Postfix service | up |
internet check | ok |
port check 80 | open |
port check 443 | open |
IP | 192.xxx.x.xxx |
gateway | 192.xxx.x.xxx |
interface | eth0 |
certificates | sherab.ddns.net |
NAT loopback | yes |
uptime | 1:18 |
