We have to AD-Groups, nextcloud_intern and nextcloud_extern.
Is it possible to connect with the LDAP-Userinterface to the AD and this to Groups?
On LDAP / USER / LDAP-Query i type in this:
(objectClass=inetOrgPerson)(memberOf=CN=nextcloud_*,OU=Nextcloud,OU=Freigabe-Gruppen,OU=GroupOU,DC=domain,DC=com)
But they will me not present any User.
AndâŚsorry for my bad englishâŚi use it not so often;-(.
I think (tho Iâm no expert) that the users tab is for collecting users and the gruops is for filtering that collection⌠i think the settings int the âusersâ tab and the âgroupsâ tab need to match. I got it to work that way anyway. For simple stuff i think you you just click on ânextcloud_internâ and ânextcloud_externâ - no need to build the string up yourselfâŚ
Have you got the basic connection working under âserverâ?
Can you see the groups youâve created in AD?
