I used the webupdating to update Nextcloud from 17.0.2 to 17.0.3.1. Then I added a new user, but he can’t login and gets an internal server error when he tries to login (Screenshot: https://cdn.discordapp.com/attachments/681614171774648410/681846730324574220/JPEG_20200225_135450.jpg).
I asked on freenode at #nextcloud but nobody could help. In the Nextcloud logs I see the following:
[PHP] Error: Invalid argument supplied for foreach() at /www/htdocs/path/to/nc/apps/serverinfo/lib/Os.php#155
GET /ocs/v2.php/apps/serverinfo/api/v1//diskdata?format=json
from 80.X.X.X by my username at 2020-02-25T19:23:14+00:00
[PHP] Error: Undefined variable: result at /www/htdocs/path/to/nc/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#173
[PHP] Error: Invalid argument supplied for foreach() at /www/htdocs/path/to/nc/apps/serverinfo/templates/settings-admin.php#101
GET /index.php/settings/admin/serverinfo
from 80.X.X.X by my username at 2020-02-25T19:23:11+00:00
[index] Error: Exception: base64_encode() expects parameter 1 to be string, null given at <>
- /www/htdocs/path/to/nc/lib/private/AppFramework/App.php line 126
OC\AppFramework\Http\Dispatcher->dispatch(OC\Core\Controller\LoginController {}, “tryLogin”) - /www/htdocs/path/to/nc/lib/private/AppFramework/Routing/RouteActionHandler.php line 47
OC\AppFramework\App::main(“OC\Core\Controller\LoginController”, “tryLogin”, OC\AppFramework\ … {}, {_route: “core.login.tryLogin”}) - <>
OC\AppFramework\Routing\RouteActionHandler->__invoke({_route: “core.login.tryLogin”}) - /www/htdocs/path/to/nc/lib/private/Route/Router.php line 297
undefinedundefinedcall_user_func(OC\AppFramework\ … {}, {_route: “core.login.tryLogin”}) - /www/htdocs/path/to/nc/lib/base.php line 997
OC\Route\Router->match("/login") - /www/htdocs/path/to/nc/index.php line 42
OC::handleRequest()
POST /index.php/login
from 185.X.X.X by the newly added user at 2020-02-25T15:58:38+00:00
How can I fix these problems?
Thank you very much for reading
