Problems after Update to 31.0.3
i ran into another issue.
The update was from 31.0.2 to 31.0.3, the instancee got stuck in Maintenance mode. can i manually deactivate in a f ile?
The instance is hosted on one.com shared hosting. All i know, is it is a linux based hosting. PHP 8.
I hope someone can help me
Yes in config/config.php
documentation
Using Nextcloud without CLI access, i.e. without access to occ, can lead to problems. Perhaps not in this case.
Yes, but there is likely a reason this happened.
Check the log per the instructions in the support template (as well as Admin Manual).
deactivation the maintanance mode resulted in the installation restarting resulting in this error:
Preparing update
Set log level to debug
Turned on maintenance mode
Repair step: Repair MySQL collation
Repair info: All tables already have the correct collation -> nothing to do
Repair step: Copy data from accounts table when migrating from ownCloud
Repair step: Drop account terms table when migrating from ownCloud
Updating database schema
Updated database
Repair step: Clean tags and favorites
Repair info: 0 tags of deleted users have been removed.
Repair info: 0 tags for delete files have been removed.
Repair info: 0 tag entries for deleted tags have been removed.
Repair info: 0 tags with no entries have been removed.
Repair step: Repair invalid shares
Repair step: Move .step file of updater to backup location
Repair step: Add move avatar background job
Repair info: Repair step already executed
Repair step: Add preview cleanup background jobs
Repair step: Migrate oauth2_clients table to nextcloud schema
Repair info: Update the oauth2_access_tokens table schema.
Repair info: Update the oauth2_clients table schema.
Repair info: Delete clients (and their related access tokens) with the redirect_uri starting with oc:// or ending with *
Repair step: Repair language codes
Repair step: Add log rotate job
Repair step: Clear frontend caches
Repair info: Image cache cleared
Repair info: JS cache cleared
Repair step: Clear every generated avatar
Repair step: Add preview background cleanup job
Repair step: Queue a one-time job to cleanup old backups of the updater
Repair step: Cleanup invalid photocache files for carddav
Repair step: Add background job to cleanup login flow v2 tokens
Repair step: Remove potentially over exposing share links
Repair info: No need to remove link shares.
Repair step: Clear access cache of projects
Repair step: Reset generated avatar flag
Repair step: Keep legacy encryption enabled
Repair step: Check encryption key format
Repair step: Remove old dashboard app config data
Repair step: Add job to cleanup the bruteforce entries
Repair step: Queue a one-time job to check for user uploaded certificates
Repair step: Repair DAV shares
Repair step: Add background job to set the lookup server share state for users
Repair step: Add token cleanup job
Repair step: Clean up abandoned apps
Repair step: Add possibly missing system config
Repair step: Add AI tasks cleanup jobs
Repair step: Queue a job to generate metadata
Repair step: migrate lazy config values
Repair step: Cache logo dimension to fix size in emails on Outlook
Repair info: Logo dimensions are already known
Repair step: Remove legacy ".ocdata" file
Repair step: Add cleanup-deleted-users background job
Repair step: Validate account properties and store phone numbers in a known format for search
Repair info: Queued background to validate account properties.
Starting code integrity check
An error occurred.
no idea what this is telling me now
