example
longer
example
here
Nextcloud version (eg, 20.0.5): 27.1.2
Operating system and version (eg, Ubuntu 20.04): Debian 12
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.57
PHP version (eg, 7.4): 8.2
The talk app and the Deck app are working with pop-up errors like (error in post or error 500).
Logs are containing a lot of errors based on Crypto.php, which fails groupfolders, cronjobs, spreed(talk) app.
It is hard
I have installed another server and it is working fine.
Two different parts of logs:
https://pastebin.com/8T02Y743
https://pastebin.com/Wj987aJk
'passwordsalt' => '*****',
'secret' => '*****',
0 => 'localhost',
1 => '*****',
'datadirectory' => '/srv/www/nextcloud/data',
'version' => '27.1.2.1',
'overwrite.cli.url' => '*****',
'dbname' => '*****',
'dbhost' => '*****',
'dbuser' => '*****',
'dbpassword' => '*****',
'instanceid' => '*****',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => '0',
'timeout' => '0.0',
'enable_previews' => 'true',
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\Movie',
6 => 'OC\\Preview\\PDF',
7 => 'OC\\Preview\\MP3',
8 => 'OC\\Preview\\TXT',
9 => 'OC\\Preview\\MarkDown',
'auth.bruteforce.protection.enabled' => 'true',
'trashbin_retention_obligation' => 'auto,7',
'defaultapp' => 'file',
'default_phone_region' => 'AT',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => '*****',
'mail_domain' => '*****',
'mail_smtpauth' => 1,
'mail_smtphost' => '*****',
'mail_smtpport' => '465',
'mail_smtpname' => '*****',
'mail_smtppassword' => '*****',
'loglevel' => 2,
'theme' => '',
PASTE HERE
PASTE HERE
PASTE HERE
