example
longer
example
here
Nextcloud version (eg, 20.0.5): 22.0.0.11
Operating system and version (eg, Ubuntu 20.04): TrueNAS-12.0-U2.1
Apache or nginx version (eg, Apache 2.4.25): nginx/1.20.1
PHP version (eg, 7.4): 7.4.21 (cli) (built: Jul 6 2021 01:55:31) ( NTS )
The issue you are facing: No ‘trusted_domains’ is needed for Nextcloud Access when Nextcloud is behind Reverse Proxy (nginx)
- Add vhost to nginx proxy server
- Comment the line related to ‘trusted_domains’
- Nextcloud will not show any error screen
Hi, everyone. I am new to Nextcloud. Currently I follow Samuel Dowling’s guide with some adjustment to build a Nextcloud server.
https://www.samueldowling.com/2020/07/24/install-nextcloud-on-freenas-iocage-jail-with-hardened-security/
After the build and some testing, I start to put nextcloud behind my nginx proxy server so that I can access nextcloud in Internet.
However, I find that if I add the below code. Some parameters like ‘trusted_domains’ will not work anymore.
I have tried to comment ‘trusted_domains’, and find that Nextcloud works as normal.
In normal operation, the ‘trusted_domains’ should be a must so that the Nextcloud will only operate in ‘trusted_domains’.
/*'trusted_domains' =>
0 => 'mynextcloud.domain',
'overwrite.cli.url' => 'https://mynextcloud.domain',
'overwritehost' => 'mynextcloud.domain',
Also, I would like to know if I need to add these codes. In my testing, tese codes have no effect of Nextcloud.
'proxy' => '',
'trusted_proxies' => [''],
Besides, there are warnings in Security & setup warnings:
Your web server is not properly set up to resolve “/.well-known/webfinger”. Further information can be found in the documentation .
Your web server is not properly set up to resolve “/.well-known/nodeinfo”. Further information can be found in the documentation .
Your web server is not properly set up to resolve “/.well-known/caldav”. Further information can be found in the documentation .
Your web server is not properly set up to resolve “/.well-known/carddav”. Further information can be found in the documentation .
Without proxy, I receive these two only, do I need to solve the problems immediately?
Should be useless, the Logging seems to be about the “Bug in DnsPinMiddleware.php, unable to resolve hostname #27870”
[PHP] Error: Invalid argument supplied for foreach() at /usr/local/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php#69
GET /index.phpajax/checksetup
[PHP] Error: count(): Parameter must be an array or an object that implements Countable at /usr/local/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php#68
[PHP] Error: dns_get_record(): DNS Query failed at /usr/local/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php#66
'instanceid' => 'instanceid',
'passwordsalt' => 'passwordsalt',
'secret' => 'secret',
'datadirectory' => '/usr/local/www/nextcloud/data',
'version' => '22.0.0.11',
//'overwrite.cli.url' => 'https://mynextcloud.lan',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/mysql.sock',
'dbuser' => 'ncdbuser',
'dbpassword' => 'ncdbpassword',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'default_phone_region' => 'HK',
'loglevel' => 2,
'enable_previews' => false,
'overwritewebroot' => '/'
From /var/log/error.log, all error are below line with different time
2021/07/20 13:58:48 [error] 13247#101924: *7955 FastCGI sent in stderr: "PHP message: PHP Parse error: syntax error, unexpected '=>' (T_DOUBLE_ARROW), expecting ')' in /usr/local/www/nextcloud/config/config.php on line 11" while reading response header from upstream, client: myPC.ip, server: nextcloud.lan, request: "GET /ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.lan"
