I’m brand new on nextcloud but I have problems to import 2 calendar in .ics.
When I imported it, it imported only a part of events, but not all of them. The problem was the same for both of the files. I tried to import it on Google Agenda, just to make a check, and everything was ok: all the events was there…
Could some of you please give me some clues to solve this problem?
. I am using the host cloud01.opsdata.ch
. The calendar I’m trying to import is a file in .ics. I tried it with files generated from different app: Outlock office, CozyCloud, Ical and Google Agenda.
. I tried to import these files from a mac and a pc, and it didn’t worked.
. There are two different calendars: each with hundreds of events.
