Hallo zusammen,
ich bekomme beim hochladen von Dateien diese Meldung angezeigt.
Expected filesize of 259463 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 8192 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Unter der Rubrik Hochladen habe ich das gefunden.
Install any NextCloud version
WARNING: this will completely wipe out your current instance
Version 18.0.7
Beta
Maximum file size 20G
Memory limit 1768M
Maximum transfer time 3600
Das sagt mir nicht viel 1768M und einfach den Wert ändern möchte ich wegen der
WARNING: this will completely wipe out your current instance nicht.
Kann mir einer einen Tipp geben was ich mach kann?
System Info
NextCloudPi version | v1.28.1 |
NextCloudPi image | NextCloudPi_12-20-19 |
distribution | Raspbian GNU/Linux 10 \n \l |
automount | yes |
USB devices | sda |
datadir | /media/myCloudDrive/ncdata |
data in SD | no |
data filesystem | btrfs |
data disk usage | 93G/466G |
rootfs usage | 2.4G/15G |
swapfile | /var/swap |
dbdir | /media/USBdrive/ncdatabase |
Nextcloud check | ok |
Nextcloud version | 18.0.7.1 |
HTTPD service | up |
PHP service | up |
MariaDB service | up |
Redis service | up |
Postfix service | up |
internet check | ok |
port check 80 | open |
port check 443 | open |
IP | 192.168.0.70 |
gateway | 192.168.0.1 |
interface | eth0 |
certificates | .org |
NAT loopback | no |
uptime | 2days |
