Hi everyone,
I allow myself to come see you in order to have a little help, because I have a rather strange behavior with Collabora Built it.
Before going any further here is the environment:
- Ubuntu Server 20.04
- Docker
- Nextcloud works in docker
- Nginx as a reverse proxy
The whole installation does not work too badly except Collabora Built it, which must be “reconfigured” each time the containers are restarted.
Let me explain :
When I start or restart the docker containers, I have to go to the settings of Nextcloud and change the configuration of Collabora Built it so that it works again.
Have you ever had this problem and how did you solve it?
Thank you
