A la hora de realizar la instalacion tuve problemas, con la bbdd me salia un mensaje de error y tuve que crear el fichero autoconfig.php.
Sin embargo, a la hora de intentarlo de nuevo me salio Error interno en el servidor.
En el log tengo:
{"reqId":"Gk6pwYIKXqM3Ae8QDIhg","level":3,"time":"2025-10-21T21:08:52+00:00","remoteAddr":"192.168.1.14","user":"--","app":"index","method":"POST","url":"/nextcloud/index.php","message":"Migration step 'OCA\\UserStatus\\Migration\\Version0001Date20200602134824' is unknown","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36","version":"32.0.0.13","exception":{"Exception":"InvalidArgumentException","Message":"Migration step 'OCA\\UserStatus\\Migration\\Version0001Date20200602134824' is unknown","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/DB/MigrationService.php","line":423,"function":"createInstance","class":"OC\\DB\\MigrationService","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/DB/MigrationService.php","line":391,"function":"migrateSchemaOnly","class":"OC\\DB\\MigrationService","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Installer.php","line":545,"function":"migrate","class":"OC\\DB\\MigrationService","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Installer.php","line":603,"function":"installAppLastSteps","class":"OC\\Installer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Installer.php","line":518,"function":"installShippedApp","class":"OC\\Installer","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Setup.php","line":447,"function":"installShippedApps","class":"OC\\Installer","type":"->"},{"file":"/var/www/html/nextcloud/core/Controller/SetupController.php","line":54,"function":"install","class":"OC\\Setup","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/base.php","line":986,"function":"run","class":"OC\\Core\\Controller\\SetupController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/nextcloud/lib/private/DB/MigrationService.php","Line":485,"message":"Migration step 'OCA\\UserStatus\\Migration\\Version0001Date20200602134824' is unknown","exception":{},"CustomMessage":"Migration step 'OCA\\UserStatus\\Migration\\Version0001Date20200602134824' is unknown"}}
Utiliza el «texto preformateado» (símbolo: </>) para enviar el contenido de los archivos de registro o los mensajes de error. Así no se puede leer realmente.
@adelaar done ![]()
