- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can.
- Nextcloud Server version (23.0.12):
- `raspberry OS bullseye
- 2.4.59
- PHP version (e.g, 8.3):
- 7.3.31
- yes
- when I tried to access nextcloud from remote.it proxy
- Bare Metal
- No
When I get to the File page I see the error “Permission denied” and if I go to the admin page I have the error message Webdav is broken. I saw this error once I started to use remote.it as proxy to my Nextcloud installation.
- Install Nextcloud
- connect remote.it to nextcloud
- navigate to the File page
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the Copy raw option from Administration settings->Logging screen or from your nextcloud.log
located in your data directory). Feel free to use a pastebin/gist service if necessary.
{“reqId”:“VaZR8GwOvm1RKasQz6re”,“level”:2,“time”:“2025-05-14T15:51:30+00:00”,“remoteAddr”:“127.0.0.1”,“user”:“TheFx”,“app”:“encryption”,“method”:“GET”,“url”:“/nextcloud/”,“message”:“Could not decrypt the private key from user "master_a24e0054"" during login. Assume password change on the user back-end.”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/136.0.0.0 Safari/537.36 Edg/136.0.0.0”,“version”:“23.0.12.2”,“exception”:{“Exception”:“OC\ServerNotAvailableException”,“Message”:“Legacy cipher is no longer supported!”,“Code”:0,“Trace”:[{“file”:“/var/www/html/nextcloud/apps/encryption/lib/Crypto/Crypt.php”,“line”:414,“function”:“getLegacyCipher”,“class”:“OCA\Encryption\Crypto\Crypt”,“type”:“->”,“args”:},{“file”:“/var/www/html/nextcloud/apps/encryption/lib/KeyManager.php”,“line”:403,“function”:“decryptPrivateKey”,“class”:“OCA\Encryption\Crypto\Crypt”,“type”:“->”,“args”:[“*** sensitive parameters replaced “]},{“file”:”/var/www/html/nextcloud/apps/encryption/lib/Hooks/UserHooks.php",“line”:182,“function”:“init”,“class”:“OCA\Encryption\KeyManager”,“type”:“->”,“args”:[" sensitive parameters replaced “,” sensitive parameters replaced “]},{“file”:”/var/www/html/nextcloud/lib/private/legacy/OC_Hook.php",“line”:106,“function”:“login”,“class”:“OCA\Encryption\Hooks\UserHooks”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/html/nextcloud/lib/private/Server.php",“line”:603,“function”:“emit”,“class”:“OC_Hook”,“type”:“::”,“args”:[“OC_User”,“post_login”," sensitive parameters replaced “]},{“function”:“OC\{closure}”,“class”:“OC\Server”,“type”:”->“,“args”:[” sensitive parameters replaced “]},{“file”:”/var/www/html/nextcloud/lib/private/Hooks/EmitterTrait.php",“line”:106,“function”:“call_user_func_array”,“args”:[{“class”:“Closure”},[" sensitive parameters replaced “,” sensitive parameters replaced “]]},{“file”:”/var/www/html/nextcloud/lib/private/Hooks/PublicEmitter.php",“line”:40,“function”:“emit”,“class”:“OC\Hooks\BasicEmitter”,“type”:“->”,“args”:[“\OC\User”,“postRememberedLogin”,[" sensitive parameters replaced “,” sensitive parameters replaced “]]},{“file”:”/var/www/html/nextcloud/lib/private/User/Session.php",“line”:922,“function”:“emit”,“class”:“OC\Hooks\PublicEmitter”,“type”:“->”,“args”:[“\OC\User”,“postRememberedLogin”,[" sensitive parameters replaced “,” sensitive parameters replaced “]]},{“file”:”/var/www/html/nextcloud/lib/base.php",“line”:1063,“function”:“loginWithCookie”,“class”:“OC\User\Session”,“type”:“->”,“args”:[" sensitive parameters replaced ***”]},{“file”:“/var/www/html/nextcloud/lib/base.php”,“line”:1004,“function”:“handleLogin”,“class”:“OC”,“type”:“::”,“args”:[{“class”:“OC\AppFramework\Http\Request”}]},{“file”:“/var/www/html/nextcloud/index.php”,“line”:36,“function”:“handleRequest”,“class”:“OC”,“type”:“::”,“args”:}],“File”:“/var/www/html/nextcloud/apps/encryption/lib/Crypto/Crypt.php”,“Line”:319,“message”:“Could not decrypt the private key from user "master_a24e0054"" during login. Assume password change on the user back-end.”,“CustomMessage”:“Could not decrypt the private key from user "master_a24e0054"" during login. Assume password change on the user back-end.”}}
{“reqId”:“0b2RTlufZfxfqNmuERGl”,“level”:3,“time”:“2025-05-15T15:45:58+00:00”,“remoteAddr”:“127.0.0.1”,“user”:“TheFx”,“app”:“core”,“method”:“GET”,“url”:“/nextcloud/index.php/core/preview.png?file=/InstantUpload/Camera/VID_20250418_130657.mp4&x=150&y=150&c=4e06877dc2116acf38cbe2e37ad13aad”,“message”:“Movie preview generation failed Output: {"0":"ffmpeg version 4.1.11-0+deb10u1+rpt1 Copyright (c) 2000-2023 the FFmpeg developers","1":" built with gcc 8 (Raspbian 8.3.0-6+rpi1)","2":" configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --libdir=/usr/lib/arm-linux-gnueabihf --cpu=arm1176jzf-s --arch=arm","3":" WARNING: library configuration mismatch","4":" avutil configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs","5":" avcodec configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs","6":" avformat configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs","7":" avdevice configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs","8":" avfilter configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs","9":" avresample configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs","10":" swscale configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs","11":" swresample configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs","12":" postproc configuration: --prefix=/usr --extra-version=0+deb10u1+rpt1 --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs","13":" libavutil 56. 22.100 / 56. 22.100","14":" libavcodec 58. 35.100 / 58. 35.100","15":" libavformat 58. 20.100 / 58. 20.100","16":" libavdevice 58. 5.100 / 58. 5.100","17":" libavfilter 7. 40.101 / 7. 40.101","18":" libavresample 4. 0. 0 / 4. 0. 0","…":"Over 20 items, aborting normalization"}”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/136.0.0.0 Safari/537.36 Edg/136.0.0.0”,“version”:“23.0.12.2”,“data”:{“app”:“core”}}
{“reqId”:“rY1kEFXuFSghacD0IUoB”,“level”:3,“time”:“2025-05-17T18:20:03+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“PHP”,“method”:“”,“url”:“–”,“message”:“Undefined index: {sabre/dav}email-address at /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Principal.php#604”,“userAgent”:“–”,“version”:“23.0.12.2”,“exception”:{“Exception”:“Error”,“Message”:“Undefined index: {sabre/dav}email-address at /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Principal.php#604”,“Code”:0,“Trace”:[{“file”:“/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Principal.php”,“line”:604,“function”:“onError”,“class”:“OC\Log\ErrorHandler”,“type”:“::”,“args”:[8,“Undefined index: {sabre/dav}email-address”,“/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Principal.php”,604,[[“principals/users/TheFx”,“TheFx”,“INDIVIDUAL”,“it”],]]},{“file”:“/var/www/html/nextcloud/apps/dav/lib/CalDAV/Reminder/ReminderService.php”,“line”:165,“function”:“getEmailAddressesOfPrincipal”,“class”:“OCA\DAV\Connector\Sabre\Principal”,“type”:“->”,“args”:[[“principals/users/TheFx”,“TheFx”,“INDIVIDUAL”,“it”]]},{“file”:“/var/www/html/nextcloud/apps/dav/lib/BackgroundJob/EventReminderJob.php”,“line”:66,“function”:“processReminders”,“class”:“OCA\DAV\CalDAV\Reminder\ReminderService”,“type”:“->”,“args”:},{“file”:“/var/www/html/nextcloud/lib/private/BackgroundJob/Job.php”,“line”:51,“function”:“run”,“class”:“OCA\DAV\BackgroundJob\EventReminderJob”,“type”:“->”,“args”:[null]},{“file”:“/var/www/html/nextcloud/lib/private/BackgroundJob/TimedJob.php”,“line”:58,“function”:“execute”,“class”:“OC\BackgroundJob\Job”,“type”:“->”,“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]},{“file”:“/var/www/html/nextcloud/cron.php”,“line”:152,“function”:“execute”,“class”:“OC\BackgroundJob\TimedJob”,“type”:“->”,“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]}],“File”:“/var/www/html/nextcloud/lib/private/Log/ErrorHandler.php”,“Line”:92,“CustomMessage”:“–”}}
{“reqId”:“qtUvA4U6WJI5GOSFqeKB”,“level”:2,“time”:“2025-05-23T08:22:16+00:00”,“remoteAddr”:“127.0.0.1”,“user”:“TheFx”,“app”:“suspicious_login”,“method”:“POST”,“url”:“/nextcloud/index.php/login”,“message”:“Detected a login from a suspicious login. user=TheFx ip=127.0.0.1 strategy=ipv4”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/136.0.0.0 Safari/537.36”,“version”:“23.0.12.2”,“data”:{“app”:“suspicious_login”}}
403 Forbidden
[Fri May 23 01:58:06.590952 2025] [so:warn] [pid 9821] AH01574: module dav_module is already loaded, skipping
[Fri May 23 01:58:06.753460 2025] [ssl:warn] [pid 9821] AH01909: connect.remote.it:443:0 server certificate does NOT include an ID which matches the server name
[Fri May 23 01:58:06.754148 2025] [mpm_prefork:notice] [pid 9821] AH00163: Apache/2.4.59 (Raspbian) SVN/1.14.1 OpenSSL/1.1.1w configured – resuming normal operations
[Fri May 23 01:58:06.754167 2025] [core:notice] [pid 9821] AH00094: Command line: ‘/usr/sbin/apache2’
[Fri May 23 01:58:14.506628 2025] [mpm_prefork:notice] [pid 9821] AH00171: Graceful restart requested, doing restart
[Fri May 23 01:58:14.582672 2025] [so:warn] [pid 9821] AH01574: module dav_module is already loaded, skipping
[Fri May 23 01:58:14.789970 2025] [ssl:warn] [pid 9821] AH01909: connect.remote.it:443:0 server certificate does NOT include an ID which matches the server name
[Fri May 23 01:58:14.791075 2025] [mpm_prefork:notice] [pid 9821] AH00163: Apache/2.4.59 (Raspbian) SVN/1.14.1 OpenSSL/1.1.1w configured – resuming normal operations
[Fri May 23 01:58:14.791142 2025] [core:notice] [pid 9821] AH00094: Command line: ‘/usr/sbin/apache2’
[Fri May 23 11:17:40.585951 2025] [access_compat:error] [pid 18048] [client 127.0.0.1:43582] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
The output of occ config:list system
or similar is best, but, if not possible, the contents of your config.php
file from /path/to/nextcloud
is fine (make sure to remove any identifiable information!):
'instanceid' => 'oc1k4is3db7y',
'passwordsalt' => '*****',
'secret' => '*****',
0 => '192.168.1.27',
1 => 'mypersonaldrive.ddns.net',
2 => 'mypersonaldrive-homepc-it-nextcloud.at.remote.it',
3 => 'k4tiku6i.connect.remote.it',
4 => '127.0.0.1',
5 => 'localhost',
'datadirectory' => '/var/www/html/nextcloud/data',
'version' => '23.0.12.2',
'overwrite.cli.url' => 'https://k4tiku6i.connect.remote.it',
'cli.overwrite.url' => 'https://k4tiku6i.connect.remote.it',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '****',
'dbpassword' => '*****',
'preview_max_memory' => 1280,
'theme' => '',
'loglevel' => 2,
'has_rebuilt_cache' => true,
'redis' =>
'port' => 0,
'timeout' => 0,
'dbindex' => 0,
'enable_previews' => true,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\TXT',
1 => 'OC\\Preview\\MarkDown',
2 => 'OC\\Preview\\PDF',
3 => 'OC\\Preview\\JPEG',
4 => 'OC\\Preview\\MP3',
5 => 'OC\\Preview\\Image',
6 => 'OC\\Preview\\Movie',
7 => 'OC\\Preview\\MP4',
8 => 'OC\\Preview\\AVI',
9 => 'OC\\Preview\\MSOfficeDoc',
10 => 'OC\\Preview\\MSOffice2003',
'app_install_overwrite' =>
0 => 'passman',
The output of occ app:list
(if possible).
- accessibility: 1.9.0
- activity: 2.15.0
- bruteforcesettings: 2.4.0
- calendar: 3.3.3
- carnet: 0.25.6
- cloud_federation_api: 1.6.0
- comments: 1.13.0
- contactsinteraction: 1.4.0
- dashboard: 7.3.0
- dav: 1.21.0
- extract: 1.3.6
- federatedfilesharing: 1.13.0
- federation: 1.13.0
- files: 1.18.0
- files_external: 1.15.0
- files_markdown: 2.3.6
- files_pdfviewer: 2.4.0
- files_rightclick: 1.2.0
- files_sharing: 1.15.0
- files_trashbin: 1.13.0
- files_versions: 1.16.0
- files_videoplayer: 1.12.0
- firstrunwizard: 2.12.0
- health: 1.6.1
- hsts: 0.9.0
- logreader: 2.8.0
- lookup_server_connector: 1.11.0
- maps: 0.2.0
- metadata: 0.17.0
- nextcloud_announcements: 1.12.0
- notifications: 2.11.2
- oauth2: 1.11.0
- onlyoffice: 7.4.8
- password_policy: 1.13.0
- passwords: 2022.12.11
- photos: 1.5.0
- previewgenerator: 4.0.0
- privacy: 1.7.0
- provisioning_api: 1.13.0
- ransomware_protection: 1.14.0
- serverinfo: 1.13.0
- settings: 1.5.0
- sharebymail: 1.13.0
- spreed: 13.0.11
- support: 1.6.0
- survey_client: 1.11.0
- suspicious_login: 4.1.0
- systemtags: 1.13.0
- talk_matterbridge: 1.26.0
- text: 3.4.1
- theming: 1.14.0
- twofactor_backupcodes: 1.12.0
- updatenotification: 1.13.0
- user_status: 1.3.1
- video_converter: 1.0.6
- viewer: 1.7.0
- weather: 1.7.7
- weather_status: 1.3.0
- workflowengine: 2.5.0
Disabled: - admin_audit
- circles: 23.1.2
- encryption: 2.11.0
- googledocsredirect: 1.0.2
- memories
- music: 1.8.4
- ocr: 6.0.58
- ocsms: 2.1.3
- passman: 2.3.4
- polls
- printer: 0.0.5
- recommendations: 0.4.0
- twofactor_gateway: 0.20.0
- user_ldap
- Use the
preformatted text
formatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
